about Overclocking ?? I have googled it...
Overclocking is the process of running a computer component at a higher clock rate (more clock cycles per second) than it was designed for or was specified by the manufacturer,
1.can it be done on intel processor (Pentium 4)
2.Is there any disadvantage of overclocking ??
When did i say overclocking? I would advice you to not overclock your cpu. Overclocking requires a good power supply and a good third party cpu cooler.
It's my personal doubt....Overclocking my CPU would brick it...is It ??
I just want to try everything on my old rig before i go in for the new one...
1 More doubt
I have a WD MyBookWorld Edition 1 T.B Lan Connectivity
The prob is the file transfer rate is very slow..Is there any way to increase it...Or this edition has it's con in this...
Reason: Automerged Doublepost
