Old 27-10-2010, 09:20 PM   #1 (permalink)
Adam young
sukesh1090's Avatar
Question case fans
can i use 3-4 8omm case fans in my cabinet which is having frontech 450w smps?Is there any 80mm case fan which makes less noise,i bought two zebronics 80mm fans but it makes a lot of noise or is there any way to reduce its noise?thank you.
sukesh1090 is offline   Reply With Quote
Old 28-10-2010, 08:15 AM   #2 (permalink)
my precious
Gollum's Avatar
Default Re: case fans
120mm case fans make less noise since they rotate slower than 80mm. But you can't really do anything about noise. Get a good psu. Your psu is considered scrap metal here
Even i had the same psu and it went kaput along with my motherboard. Better invest in a good psu. Your current psu will not last long with 4 case fans.
Gollum is online now   Reply With Quote
Old 28-10-2010, 08:46 AM   #3 (permalink)
@OP - difficult to get 80mm case fans of a good brand(CM,Noctua).So far Ihv come across only 120mm fans from these c/os.
ssb1551 is offline   Reply With Quote
Old 28-10-2010, 12:14 PM   #4 (permalink)
Adam young
sukesh1090's Avatar
thank you for your reply guys.seems that i really in need of changing that psu.
