LinkBack (3) Thread Tools Display Modes
Old 25-10-2010, 12:17 AM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Unlocking Athlon II X3 to Phenom II X4
I just upgraded my system to Athlon II X3 440 with Asus M4N98TD EVO MoBo. My system was able to boot fine the very first time and I was able to unlock 4th core of my Proc. But instead of Athlon II X4 (as expected) the processor shows as Phenom II X4 B40. Is it OK? I thought Phenoms were Athlons with L3 cache enabled.
Also is there any method to revert back to Athlon II X3 from here? Will simple BIOS reset do the job?
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline   Reply With Quote
Old 25-10-2010, 12:31 AM   #2 (permalink)
Swimming, eh??
toad_frog09's Avatar
Default Re: Unlocking Athlon II X3 to Phenom II X4
Did you use Cpu-Z to check it out??
I can never tell the difference between a man choking to death or a man beatboxing. So I always start dancing just in case.
toad_frog09 is offline   Reply With Quote
Old 25-10-2010, 10:27 AM   #3 (permalink)
CPU-Z too shows processor as Phenom II X4 B40. L3 cache is not available though.
Old 27-10-2010, 05:40 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ is it stable as Phenom II X4 B40 - if so then why reverse it as you are getting the power of one additional processing core.
if you still want to reverse it back to x3 - yes a simple bios reset should do it.
BTW, update your siggy.
ToPsPeEeD = FaSt BuT StEaDy
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/133262-unlocking-athlon-ii-x3-phenom-ii-x4.html
Thread Unlocking Athlon II X3 to Phenom II X4 | Digit Forum | BoardReader This thread Refback 09-03-2011 03:10 PM
Thread Unlocking Athlon II x3 445 (info, screenies etc) | techPowerUp! Forums | Page 2 | BoardReader This thread Refback 07-01-2011 05:02 PM
Thread Unlocking Athlon II x3 445 (info, screenies etc) | techPowerUp! Forums | BoardReader This thread Refback 03-11-2010 11:58 PM
