LinkBack (2) Thread Tools Display Modes
Old 22-10-2010, 12:38 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Techno Freak
Default Cooler Master Hyper 212 Plus VS Thermalright Ultra-120mm
hello all,
I m sooner Buying this hSF for My AMD phenom x4 965 BE proccy.
i have
1. Amd Phenom X4 965 B.E.
2. Asus ASUS M4A785TDV-EVO
3. 550 w PSU.
4. 2 Gb DDR Transcend Ram.
My Budget is < 3k.
I got 2 result While goggling as:
1.Thermalright Ultra-120mm == 3k
2.Cooler Master Hyper 212 Plus == 2.2k
Cooler Master Hyper 212 Plus is avialable in my Local Dealer.
(as he have only one HSf and when asked for Other, he even dunno and told not to Buy other brands )
Thermalright Ultra-120mm : IS on theitdeport.com at 3200 /- (with shippment)
i want to know which should i Buy ?
please tell me Pros and cons and what will u buy if u will buy ?
(Pros: Cooler Master Hyper 212 Plus: Uneven base due to copper and solid base)
suyash_123 is offline   Reply With Quote
Old 22-10-2010, 01:48 PM   #2 (permalink)
This Is Saggi Here...
Default Re: Cooler Master Hyper 212 Plus VS Thermalright Ultra-120mm
Dude,
Go With Cooler Master Hyper 212 Plus...
Am Using It And Its Good...
Secondly Buying Online Sucks...
You Have Got A Local Vendor Then Stick To It And Buy It...
It Will Cost You 2.1K Only...
And You Can Add 1 Extra Fan With It.. 2.1K + 3 = 2.4K...
The Best Option For you...
systechsolution is offline   Reply With Quote
Old 24-10-2010, 06:54 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
@ suyash_123 - Thermalright Ultra-120 don't comes with a fan - so you have to cough up another 500 bucks to get a decent 120mm fan. so it will be 3.5k total - if you can spend that much it would be a solid cooler for your rig.
If you don't want to spend that much gget CM Hyper 212 ( normal - it has flat base ) or Hyper 212+ - they both comes with fans and 212+ is compatible with all latest intel sockets too.
ToPsPeEeD = FaSt BuT StEaDy
Old 24-10-2010, 05:17 PM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
@ OP
Which case r u using ??
BTW u have to spend extra for FAn as TOPGEAR said go with Hyper 212+ , see in my sig im using with phenom 2 940 . anyway Phenom 2 965 is 125W TDP 30 to 34 will be idle & 50 to 57 will be load even with TRUE 120
damngoodman999 is offline   Reply With Quote
Old 27-10-2010, 12:08 PM   #5 (permalink)
Techno Freak
Now going to Buy COOOOOOOOOOOOOOOOOLER master 212+ soon!
and with extra Fan!!!! if possible..
i want COOOOOOOOOOLer CPU!
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/133193-cooler-master-hyper-212-plus-vs-thermalright-ultra-120mm.html
Thread v8 vs hyper 212 plus vs hyper n620 vs hyper n520 | Guru3D.com Forums | BoardReader This thread Refback 08-12-2010 07:58 PM
Thread P6X58D Premium Hyper 212+ G. Skill 12gb Ram | Toms Hardware Forums | BoardReader This thread Refback 27-11-2010 01:42 AM
