Old 22-10-2010, 12:21 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Hybrid TV Tuner for Phenom X6.
Kindly help me to buy a tv tuner card which can record both analog and digital tv.(Hybrid mode) My config is AMD Phenom X6 1055T based. Kindly suggest the best one in all category (internal,external) USB is preffered.
Thanks.
bobgalee is offline   Reply With Quote
Old 22-10-2010, 07:26 PM   #2 (permalink)
vwad's Avatar
Location: Why ? Are you coming for dinner ? Pls. Don't.
Default Re: Hybrid TV Tuner for Phenom X6.
Recording Digital TV is not that simple with new TV tuners since there is macrovision protection enabled for DTH services. (My Experience with TATA SKY) so you only have one choice and that is to use RF connector to record.
In that I would recommend you
Leadtek Winfast DTV 1800 H or DTV 2000 H
If you can afford go for monster, DTV 3200 H
Here are links to buy these
http://www.theitdepot.com/details-Le..._C53P5427.html
http://www.theitdepot.com/details-Le..._C53P5428.html
http://www.theitdepot.com/details-Le..._C53P5429.html
An Old Lady Died In Her Childhood.
vwad is offline   Reply With Quote
Old 23-10-2010, 08:15 AM   #3 (permalink)
my precious
Gollum's Avatar
You mean that recording the video out of the composite connector of tatasky is not possible?
Gollum is online now   Reply With Quote
Old 23-10-2010, 01:18 PM   #4 (permalink)
vwad's Avatar
Yes. I have tried it myself. With the Card PVR as well as Intervideo WinDVD Recorder Platinum 5. You can watch easily but once you press record button, you get only ants on screen.
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/133191-hybrid-tv-tuner-phenom-x6.html
Thread Best motherboard for AMD Phenom X6 1075T? | Digit Forum | BoardReader This thread Refback 13-05-2011 02:30 PM
