Old 21-10-2010, 10:58 AM   #1 (permalink)
Default Strange problem !!!
Hi everybody !!
Have got stuck in a strange situation. one of my friends PC starts automatically as soon as the power is put on and goes off automatically after 15-20 seconds. and then it never gets on. Have tried changing the RAM, SMPS, CMOS battery, without connecting the HDD and DVD RW. All in vain, has the motherboard gone kaput. Configuration is :_
Inter Dual Core E5200
Gigabyte GA-945gcm-SL2
DDR II 1 GB
Mercury 450W SMPS
Please help me out quick.
sanju_nlp81 is offline   Reply With Quote
Old 21-10-2010, 11:21 AM   #2 (permalink)
Default Re: Strange problem !!!
check the power supply and the earthing as well...???
P2 x4 955 B.e,ga880gm-usb3,corsair 6gb,tx650,sea 1tb+500*2,cm690 with 7 fans 120mm,curve 2000 and mx518,sony &hp optical drive,sunbeam cold cathode*2 & bubble lights,benq g2222hdl.samsung 32"full hd.
Arnab boss is offline   Reply With Quote
Old 21-10-2010, 11:36 AM   #3 (permalink)
Have checked everything. My earthing is best in the area
Old 21-10-2010, 11:50 AM   #4 (permalink)
my precious
Gollum's Avatar
I have the same problem. But my PC does not turn on by itself.
I think its the fault of the smps which has taken the motherboard with itself.
My motherboard is Asus M2nVM-dvi [am2 cpu support, ddr2 800, 4 sata, 4 dimm slots, 1 pcie x16 @x16, 2 pci, 1 pcie x1 slot)
I also have an el cheapo psu.
gonna buy COrsair cx400 and play cricket with the el cheapo psu and post a video on yuotube.
Gollum is online now   Reply With Quote
Old 21-10-2010, 12:07 PM   #5 (permalink)
Does 945 chipset supports properly e5200 ?
gcbeldar is offline   Reply With Quote
Old 21-10-2010, 05:54 PM   #6 (permalink)
GIGABYTE TECHNOLOGY Socket 775 - Intel 945GC
Here is the list of supported CPU's by Gigabyte!!!
Old 21-10-2010, 11:26 PM   #7 (permalink)
Originally Posted by sanju_nlp81 View Post
Hi everybody !!
DDR II 1 GB
Mercury 450W SMPS
I had the same prob when my MoBo busted!!n I tot it was coz of cheap PSU but that damn thing was n is working fine!!I think u gotta hunt for a new MoBo!!
ssb1551 is offline   Reply With Quote
