When I type 192.168.1.1 in any browser, the modem interface doesn't open, it simply says unable to open or whatever depending on the browser. I tried the same modem on another PC and it works. What could be the problem?
I used ethernet port to connect at both places. The modem is working fine as far as internet connection goes.
__________________ Digital Sheets Technology Blog
Nokia 5230 :(
Canon IXUS 115 HS :)
Did you try changing the lan card driver? Or a different lan card.
Did you run the network setup wizard for small home office network to set your default network connection for internet as lan.
You re-installed your OS too!!!!!!!!!
Have you tried resetting the modem because I think it is issue from modem side only. Secondly a different LAN cable could also do the trick.
My personal blog - http://gagan.scholarguru.com
Use any Linux live cd and try to type in the live session either in firefox or konqurer
Linux is not merely an operating System..It is a movement to safeguards your freedom..So our future generations don't blame us, that we push them to the enslavement of $ :http://linxbot.wordpress.com/
