Originally Posted by redlofredlof
i don't think 450w psu will be enough for your graphics card and tv tuner. Tv tuner wont take too much of power. But the gpu will.
To fit the card you need to worry about the computer case. It should be big enough to fit inside the case. It will fit easily on the mobo
Case is Cooler Master 310 Elite.
I think it'll fit inside the case,
but will it run? Chances are psu might blow up?
if so...any other external cards? i have a 17inch crt by the way.
