LinkBack (3) Thread Tools Display Modes
Old 16-10-2010, 03:34 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
Default AMD PII X2 555 BE Unlock core Problem!!!
pals....
i bought a pc 8 months ago..config....
AMD PII X2 555 BE + ASUS M4A78LT-M LE + 2GB DDR3
and used the mobo to unlock the rest of the cores......
the pc is working fine...
so yesterday i bought another pc with same mobo and proc....
but this time when i try 2 unlock the cores....
i only get, "Enabling Unleashing Mode Failed"
tried every setting in acc, also changed the core settings.....
but all failed, tried to decrease the ht frequency from 2000 to 1600
but that 2 failed....
also downgraded the bios of the new mobo to the old 1 but that 2 failed...
needed help....
thanx
angel
The Day Walker! is offline   Reply With Quote
Old 17-10-2010, 11:04 PM   #2 (permalink)
adirawat20's Avatar
Default Re: AMD PII X2 555 BE Unlock core Problem!!!
did you reset the cmos.
First time heard problem
adirawat20 is offline   Reply With Quote
Old 18-10-2010, 09:47 AM   #3 (permalink)
Wise Old Ghoul
Piyush's Avatar
yes ...reset the cmos battery and then try again
could be the problem with bios too coz ASUS bios are becoming pain these days
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 18-10-2010, 11:31 AM   #4 (permalink)
k will try 2 reset the cmos battery and c.....
as i have tried 2 upgarde the bios adn also downgrade the bios.....
but it didnt work......
thanx
angel
Old 18-10-2010, 05:57 PM   #5 (permalink)
pegasus's Avatar
I had heard some months back that new batches of X2 555 BE may not unlock successfully.
Since you bought the processor recently, it may be the issue in your case.
pegasus is offline   Reply With Quote
Old 19-10-2010, 12:42 PM   #6 (permalink)
i think thats the case...
cause i have done everything 2 unlock it... but its all in vain....
the buyer was giving me an old stocked x2 550 be proce..but i thought
its better 2 go in for a new 555
****,,if i would have taken the old stock wala..then it would have been a quad core...
thanx
angel
Old 24-10-2010, 01:20 PM   #7 (permalink)
Rocket Load To All....
Ayush_ANI's Avatar
do you enable the mob core unlocker switch.........???? Check it first....... then enable again...
AMD PHENOM II x4 955 || ASUS M4A89GTD-PRO ||CORSAIR DDR3 4GB KIT || SEAGATE 1X2TB HDD || ASUS DVD R/W || COOLER MASTER 650W || Cooler Master N520 || HD 5670 1GB ||CREATIVE 5.1 || ZEBRONICS REAPER ||
Ayush_ANI is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/132995-amd-pii-x2-555-unlock-core-problem.html
Thread AMD PII X2 555 開四 測試 | 電腦領域 HKEPC Hardware - 全港 No.1 PC討論區 | BoardReader This thread Refback 21-05-2011 11:49 PM
Thread AMD PII X2 555 BE Unlock core Problem!!! | Digit Forum | BoardReader This thread Refback 05-01-2011 09:45 PM
Untitled document This thread Refback 05-01-2011 04:52 PM
