Old 15-10-2010, 11:23 AM   #1 (permalink)
rahul_c's Avatar
Default Carnuda car wax in laptop!
Is it ok to apply car wax to laptop glossy parts? I did it for the first time today and it has increased shine significantly(scratches only visible in direct sunlight) the box of wax says it's not recommended to do that!
rahul_c is offline   Reply With Quote
Old 15-10-2010, 11:24 AM   #2 (permalink)
rahul_c's Avatar
Default Re: Carnuda car wax in laptop!
see this pic - Yfrog Image : yfrog.com/j842gzj - Uploaded by rahul_choudhary
Old 15-10-2010, 12:39 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Wow...interesting. Would not this type of wax have strong(er) toxins / chemicals which your laptop can sustain. On the long run it might cause issue --- bad look, flaking, or corrosion.
Would rather not.
asingh is online now   Reply With Quote
Old 15-10-2010, 01:10 PM   #4 (permalink)
rahul_c's Avatar
its been a while i dont see any problems, the polish also resist scratches n the surface is super smooth
Old 15-10-2010, 01:55 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Your laptop. Best of luck..!
Old 15-10-2010, 06:18 PM   #6 (permalink)
rahul_c's Avatar
I will post here if I experience any problem in future
Old 15-10-2010, 07:49 PM   #7 (permalink)
my precious
Gollum's Avatar
Dude! You do not use car wax on laptop. Use shoe polish
Gollum is online now   Reply With Quote
Old 31-12-2010, 08:56 AM   #8 (permalink)
rahul_c's Avatar
Thumbs up Re: Carnuda car wax in laptop!
Months have passed haven't experienced any problem yet :roll:
Old 03-01-2011, 07:32 AM   #9 (permalink)
Adam young
sukesh1090's Avatar
if it works cool without any problem then just tell me,i will also try that
BTW how many months have passed after applying that car wax? And guys is there any liquid which can clean the screen of my lcd monitor?
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 03-01-2011, 10:49 AM   #10 (permalink)
I wanna know about that too!!Some shops at my place have some products which they say is to "clean the LCD monitors" for 200-300/-.Will that stuff do?or should I buy good ones?Anybody know any good brands?
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
ssb1551 is offline   Reply With Quote
Old 04-01-2011, 08:52 PM   #11 (permalink)
rahul_c's Avatar
Its been about 3 months, I personally use any mirror cleaner (like-collin) for screen but never spray them directly to screen use a cloth.
