Old 13-10-2010, 06:33 PM   #1 (permalink)
ajayritik's Avatar
Default Will my rig support 1 TB Internal HDD
I have 1 GB RAM , Core 2 Duo 2.13 Ghz and have a 60 GB Internal IDE HDD. I plan to upgrade my HDD to either 500 GB or 1 TB. Can someone please suggest whether my Rig will support a 1 TB HDD and do I have to upgrade RAM for better results.
ajayritik is offline   Reply With Quote
Old 15-10-2010, 05:42 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Will my rig support 1 TB Internal HDD
the details you've provided is very little and you have not told the model name of your mobo though as you have told you have a c2d cpu based rig your rig will support 1TB or even 2TB SATA HDD .
ToPsPeEeD = FaSt BuT StEaDy
Old 15-10-2010, 06:55 AM   #3 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
YES....
HDD Capacity Support does not depend on ur ram , CPU and AKAIK also Mobo.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline   Reply With Quote
Old 15-10-2010, 10:58 AM   #4 (permalink)
ajayritik's Avatar
I have intel based motherboard don' remember the exact chipset.
Old 15-10-2010, 02:43 PM   #5 (permalink)
bringing the world down
hdknitro's Avatar
ya u can put a 1TB HDD, better go with 1TB WD caviar blue or Seagate barracuda 1TB. Both are 7200 rpm. Both are gud
'''LET THE POWER BE RAW'''
AMD Phenom X6 1090 T, Gigabyte 88O, G-Skill ribjaw 1600mhz (4 gb), WD Caviar Black 1.5 TB, Sapphire HD6870 1GB, CM GX 650, CM Centurion 590, 6 fan cooling system
hdknitro is offline   Reply With Quote
Old 15-10-2010, 07:46 PM   #6 (permalink)
my precious
Gollum's Avatar
Hard disk size is os dependent. Windows xp and above will support any size just remember to keep the file system NTFS. Fat32 can only support max single file size of 4gb.
Gollum is online now   Reply With Quote
Old 16-10-2010, 04:54 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
Originally Posted by Power_user_EX View Post
YES....
HDD capacity in earlier days were dependent on the mobo and bios and the OS though modern day's mobos has no such limitation.
Old 18-10-2010, 10:08 PM   #8 (permalink)
Smile Re: Will my rig support 1 TB Internal HDD
Its obvious that he is not using UNIVAC.... and its 2010... so some things are obviously assumed.
Old 19-10-2010, 06:17 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
sure he is not using a UNIVAC from 1950's
I've assumed about his modern age rig by looking at the Core 2 Duo 2.13 Ghz word.
Old 19-10-2010, 02:43 PM   #10 (permalink)
ajayritik's Avatar
Ok guys based on your answers looks like I can go for a 1 TB Internal HDD.
Just wanted to inform that the motherboard I have is DG 965 RY. Though I know it may not be of any consequence.
Old 20-10-2010, 04:02 AM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
there should not be any kind of consequence - just go ahead and buy a 1TB or even 2TB hdd.
