Old 13-10-2010, 06:30 PM   #1 (permalink)
ajayritik's Avatar
Default Can I convert my internal HDD To external? If so how?
I have an internal HDD 60 GB IDE. Can I convert this to an external HDD using case available.
How much would this cost and is it a good idea?
ajayritik is offline   Reply With Quote
Old 13-10-2010, 06:41 PM   #2 (permalink)
aniket.cain's Avatar
Default Re: Can I convert my internal HDD To external? If so how?
Yes, of course. You need to buy an external HDD casing for it. Just go to a computer hardware shop and ask for it. It will cost you around Rs. 500.
And though 60GB is not much these days, it can still be used as a backup for data. The downside is that it will have a power adapter of its own, and will be heavy and cumbersome to carry around.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 14-10-2010, 09:00 AM   #3 (permalink)
newway01's Avatar
Good. . And is there an external casing supporting both ide and sata?
newway01 is offline   Reply With Quote
Old 14-10-2010, 09:09 AM   #4 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
There are external Cases for SATA hdds too. But I'm not sure that You'll be having both IDE and SATA both in a single case.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 14-10-2010, 10:12 AM   #5 (permalink)
New Gen Guru
sujoyp's Avatar
I have both external casing for IDE and SATA...its not possible to support both in single casing...
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now   Reply With Quote
Old 14-10-2010, 10:25 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
@ajayritik: External Casings for IDE & Sata are available.....i m using my 40GB
HDD as external drive....in casing.....
they will cost u rs500~800
yes i m using one having both options of SATA & IDE....
Old 14-10-2010, 11:23 AM   #7 (permalink)
ajayritik's Avatar
By having two options are you asking whether the same external case can be used for both SATA as well as IDE internal HDD?
Old 14-10-2010, 01:05 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
yes it can use SATA & IDE drives.....because connectors r supplied with it...
Old 14-10-2010, 03:56 PM   #9 (permalink)
instead of buying a casing, i wud suggest a sata ide to usb adapter.... hv been using it since past 6months... best part is i can connect any IDE/SATA harddisk directly to USB using it...
and it will cost u around 350rs
sata ide to usb adapter - Google Search
Warm Regards,
ISRAR AMRELIA
israramrelia is offline   Reply With Quote
Old 14-10-2010, 07:03 PM   #10 (permalink)
ajayritik's Avatar
How about the portability of the Internal HDD. If we have an external casing don't you think it will be easier to carry around. I think your option would work if we don't intend to move the the HDD outside etc.
Old 14-10-2010, 07:17 PM   #11 (permalink)
XLr8
arpanmukherjee1's Avatar
if portablity is an issue i highly recommend to go 4 130GB or 360GB transcend/segate external drive.
ur 60GB hdd might be too old and unreliable and small to act as backup drive.
else the SATA-USB adapter is good enough
arpanmukherjee1 is offline   Reply With Quote
Old 19-10-2010, 05:13 PM   #12 (permalink)
ajayritik's Avatar
Dude where would I have to connect the power adapter? Do I need to open up my cabinet for this?
Old 19-10-2010, 06:57 PM   #13 (permalink)
is this a 3.5" HDD or 2.5" ? if it is a 3.5", then you will need to give external power to the hdd....which is bad imo..
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 19-10-2010, 08:15 PM   #14 (permalink)
ajayritik's Avatar
Since mine is a desktop HDD so I assume its a 3.5". So maybe I have to go for external casing rather than the SATA/IDE USB connector as suggested by israramrelia
Old 19-10-2010, 09:44 PM   #15 (permalink)
even if you get an external casing,you need to power it using an external adapter...
Old 20-10-2010, 10:33 AM   #16 (permalink)
Fullbring
Zangetsu's Avatar
so whats the big deal...
Old 20-10-2010, 10:58 AM   #17 (permalink)
ajayritik's Avatar
That's Ok. As long as I don't have to open my Cabinet to connect the HDD power socket.
Old 20-10-2010, 11:32 AM   #18 (permalink)
the big deal is that you need to hook it up to an adapter for power,you need to look for a power socket near by, which is irritating,at least for me.....
Old 20-10-2010, 12:09 PM   #19 (permalink)
Fullbring
Zangetsu's Avatar
lolz buy a spyguard plug then
Old 20-10-2010, 12:17 PM   #20 (permalink)
ajayritik's Avatar
Sorry if I'm sounding noob but by spyguard do you mean spike?
Old 20-10-2010, 12:21 PM   #21 (permalink)
Fullbring
Zangetsu's Avatar
go2 any hardware shop & ask for spyguard......
Old 20-10-2010, 02:04 PM   #22 (permalink)
whats a spyguard?
Old 20-10-2010, 02:24 PM   #23 (permalink)
abhidev's Avatar
dude...its a SPIKE GUARD
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
Old 20-10-2010, 04:02 PM   #24 (permalink)
Fullbring
Zangetsu's Avatar
hehe..its my mistake....spikeguard....
Old 20-10-2010, 07:02 PM   #25 (permalink)
lol
But then,its a problem when you go in a public place, like college,where its hard to locate the power socket (and you are not allowed to move stuff), plus carrying it along with the adapter...hmm....up to the user really..
Old 22-10-2010, 10:18 PM   #26 (permalink)
Rocket Load To All....
Ayush_ANI's Avatar
hi friends is any one know hd 5670 can run metro 2033 game??????? Plz help. If can run then i buy it....
Thanks for help......
AMD PHENOM II x4 955 || ASUS M4A89GTD-PRO ||CORSAIR DDR3 4GB KIT || SEAGATE 1X2TB HDD || ASUS DVD R/W || COOLER MASTER 650W || Cooler Master N520 || HD 5670 1GB ||CREATIVE 5.1 || ZEBRONICS REAPER ||
Ayush_ANI is offline   Reply With Quote
Old 22-10-2010, 10:58 PM   #27 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
^^ hhey y u posting in multiple threads at random..??? plz check the link in my siggy for ur answer... and for ur Q'... YES, ur card can play metro 2033....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now   Reply With Quote
Old 23-10-2010, 09:59 AM   #28 (permalink)
Fullbring
Zangetsu's Avatar
does your college allow pendrive,HDDs.....??????amazing...
college pc has deadly viruses...becoz lots of students use pendrive,cd etc...
Old 24-10-2010, 06:50 PM   #29 (permalink)
newway01's Avatar
^^^ Yes, thats very true.. And whats special about my college is that, if I plug in a pendrive to any pc on my lab, then that pendrive wont work ever.. I have replaced myself 3 sandisk drives..
Old 25-10-2010, 12:13 PM   #30 (permalink)
Fullbring
Zangetsu's Avatar
statutory warning: Using pendrives/portable drives in Colleges may b injurious to
their health.
