Old 11-10-2010, 10:19 PM   #1 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Cool GacialPower PSU RMA in India ?
I wanna know if PSUs from GacialPower can be RMA'd in India itself or i have to send it to Taiwan.
Either way i wanna know the procedure ...
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline   Reply With Quote
Old 11-10-2010, 11:18 PM   #2 (permalink)
The Sorcerer's Avatar
Default re: GacialPower PSU RMA in India ?
There should be a distributor's sticker on glacialpower's box. If so, contact them.
Or else its best if you give it to your dealer, assuming he is a proper one he will do the needful.
Hardware BBQ
The Sorcerer is offline   Reply With Quote
Old 12-10-2010, 01:24 AM   #3 (permalink)
Actually i asked it bcoz i m stuck between Corsair TX850W (80+) and GlacialPower AX950AA(90+).
HX850 (90+) is an option but its around 9.5K and around 9k i get 100W more with AX950AA with same performance.
So shud i get a TX850 which around 7.3K or get a AX950AA which costs 9k but afraid of after sales service and RMA issues if i have one.
primeabgb is selling AX950AA.
Old 12-10-2010, 02:03 AM   #4 (permalink)
Techie By Heart
mavihs's Avatar
get HX850, its got longer warranty period then Glacial!!!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 12-10-2010, 10:08 AM   #5 (permalink)
Config please! Its just not right to blindly advice without knowing the needed info.
Hardware BBQ
Old 12-10-2010, 09:14 PM   #6 (permalink)
Default Re: GacialPower PSU RMA in India ?
my config : P5Q Deluxe , Q6600 , 4870+4850 (currently using 4870 due to my retarded PSU and wont handle both) , 4 HDDs (1 Black + 3 Green), CM690 cabinet + some FANS....
Config is not important coz i want a future proof PSU which can handle my OC needs and 2x 5870s in CF and BTW Q6600 @ 3.6Ghz @ 1.41V Consumes around 135W on my PC.
With my current Config my PC heats up a lot coz of my bad cable managment so need a PSU that can give around 85% eff at around 50 degs...
Also the temps are high due the fact that both 4870 and 4850 idle around 68 to 71 Degs with GPU Fan speed to Auto and around 60 Degs with 100% GPU fan speed... The 4800 series sucks in terms of Heating..
and... OOPS MY Current PSU is CM extreme power 600W - shame on me....
Also i need a high wattage PSU bcoz :
1) Will go CF with newer ATI cards and a complete upgrade in Future
2) my normal load is(will be) about 450-500W so eff at this wattage must be higher... and AFAIK with 80+ PSUs 40 to 60% Load gives max eff.
Old 13-10-2010, 04:36 AM   #7 (permalink)
Stick to HX850. They are adequate for your needs if you are planning for a CF system.
Hardware BBQ
