Old 10-10-2010, 09:15 PM   #1 (permalink)
Living to Succeed
ajayashish's Avatar
Default Suggest a rig within 8k
i want a machine within 8k or less for surfing and watching movies. I already have a monitor.
Please suggest me something which can be within the budget and i will be buying the same in 2-3 weeks time.
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline   Reply With Quote
Old 10-10-2010, 09:48 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Suggest a rig within 8k
Here goes your config:
Processor: Athlon II 245 @ 2.6k
Motherboard: BIOSTAR MCP6PB M2+ NVIDIA GeForce 6150 @ 2.07k
Ram: 2 GB Dynet DDR2 800 MHz @ 1.7k
HDD: Seagate 500 GB @ 1.6k
Cabinet & SMPS: Any Local Cabinet with 450W SMPS @ 1k
Keyboard & Mouse: @ 0.35k
Total is 9.32k. The price can be reduced by going for a Sempron 140 @ 1.7k, but now a days dual core is advisable.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is offline   Reply With Quote
Old 10-10-2010, 10:03 PM   #3 (permalink)
Nice config..well within 8-9k but noway looks underpowered for that budget.
nomad_s is offline   Reply With Quote
Old 10-10-2010, 10:03 PM   #4 (permalink)
Wise Old Ghoul
Piyush's Avatar
i thought it was impossible!!!!
great work clius
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 10-10-2010, 10:28 PM   #5 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
Tight budget but a great suggestion by Cilus..
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now   Reply With Quote
Old 10-10-2010, 10:43 PM   #6 (permalink)
Living to Succeed
ajayashish's Avatar
Nice one... thanks ... any other suggestion
Old 10-10-2010, 10:53 PM   #7 (permalink)
laborare est orare
Cilus's Avatar
Thanks Everybody. For cheap but great components check anythinginIt and deltapage. They have a very good list of cheap components and ideal for making budget systems.
ajayashish, if you can extend your budget to 10k, I can try a DDR3 based system which will be a little future proof.
Motherboard: MSI GF615M-P33 @ 2.6k
Ram: 2 GB DDR3 Dynet @ 1.7k
Total 9.85k
Old 10-10-2010, 11:09 PM   #8 (permalink)
Living to Succeed
ajayashish's Avatar
nope... i want to keep it as less as possible...
it will only be used for surfing and watching movies... it is specially for my dad and no games as such will be played...
so want to keep it as low as possible...
