View Poll Results: which is better
intel iz 8x series 0 0%
phenom ii x6 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 10-10-2010, 05:31 PM   #1 (permalink)
tech geek
imsidz's Avatar
Exclamation Will it run "maya 2010" + aE
JJST PLANNING TO build up a strong pc
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: high end comp. dat kan run 'ae' + hard core games
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: yup!
3. What is your MAX budget?
A:50k inr
4. Planning to overclock?
A:sure
A:win se7en premium
A:1TB+
7. What resolution will the screen run at & whats the size of the screen you want?
A:24'inch
A:8
A:ya!
A:this DHANTERASH
A:atleast fr 2-3yrs
A:grfx crd
A:patna,bihar--ya can!
A:guys m building this config for animation desgn wrk and some kool gming e.g. cod4mw2/crysis
gonna buy grfx crd later within 2 mnths
:-P:-P:-P:-P:-P:-P:-P:-P:-P:-P
reply plz
imsidz is offline   Reply With Quote
Old 10-10-2010, 10:22 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Will it run "maya 2010" + aE
Phenom II X6 1090T 3.2 GHz @ 13.8k
MSI 880GMA-E45 @ 5.8k
Kingston 2 X 2 GB 1333 MHz DDR3 @ 4.4k
Seagate 1 TB with 32 MB Cache @ 2.8k
PSU: Corsair VX550W @ 4.7k
Cabinet: Cooler Master Elite 342 @ 2.2k
BenQ 24" G2420 FULL HD LCD Monitor @ 11.3k
Altec Lansing VS-2521E @ 2.9k
Keyboard & Mouse @ 1k
Total 48.9k + Vat.
Now one thing, in a 24" full HD monitor (1920X1080P), hard core gaming is not possible if you don't have a high end card, at least GTX 460 1 GB or HD 5830/HD 5830. So better keep at least 13k for a good Graphics card.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is offline   Reply With Quote
Old 12-10-2010, 06:40 AM   #3 (permalink)
tech geek
imsidz's Avatar
So - will the i7 870 not be the best buy. . Any difference between phenom ii x6 1090t and i7 870. . Please reply . . M asking because never used amd
Old 12-10-2010, 06:55 AM   #4 (permalink)
tech geek
imsidz's Avatar
As for e.g. Bench - CPU - AnandTech :: Your Source for Hardware Analysis and News for cpu suggests that i7 870 is better than ii x6 1090t @ sysmark 2007{overall} need reply
Old 12-10-2010, 10:23 AM   #5 (permalink)
Swimming, eh??
toad_frog09's Avatar
Well, you would be spending a lot on mobo if you get i7.
Btw, can we get to know your budget for gfx card which u'l buy later?
toad_frog09 is offline   Reply With Quote
Old 12-10-2010, 10:38 AM   #6 (permalink)
laborare est orare
Cilus's Avatar
Ya, Core i7 870 is a better performer than Phenom II 1090T in some applications. So if you want you can go with it. But with coming days, all the software are getting more and more multi-threaded and multi-core aware. So in near future the 6 cores of Phenom II X6 will be utilized fully and will yield some extra performance boost.
2ndly, Phenom II 1090T is a Black Edition processor, so have great overclocking potential. Using the stock cooler you can easily reach 3.6 GHz to 3.8 GHz. Then sometimes the performance is over all the Intel counterparts except the new Intel Core i7 980 6 Core processor.
Old 12-10-2010, 10:49 AM   #7 (permalink)
Swimming, eh??
And while we are at it.
CPU COOLER:
1. Spire thermax eclipse II.
2. thermaltake frio.
3. Noctua nh-d14
4. 3Rsystem iceage 120 boss II
5. Tuniq tower 120 extreme.
All these are above 3.5k.
Best in the business.
Old 12-10-2010, 12:21 PM   #8 (permalink)
Jaskanwar Singh's Avatar
Total 48.9k + Vat.
problem is msi 880gma e45 doesnt support 125w processors such as 1090t and 1055t. only 95w 1055t supported..check msi website.
Old 12-10-2010, 07:27 PM   #9 (permalink)
tech geek
imsidz's Avatar
approx.. 10~15k :-P
Old 12-10-2010, 07:35 PM   #10 (permalink)
tech geek
imsidz's Avatar
k! f9 but here guys jst hate amd and says it doesn't wrk right is anything like that ???
so will that stuff rock solid and work with no hesitation !!
and since myself not buying gfx card within 2~3mnths .......
will the config accrding to you be able to run the games like cod4mw2 / crysis ????
reply plz
Old 13-10-2010, 02:35 AM   #11 (permalink)
Swimming, eh??
Nobody hates anything here. (apart from intel mobo, CM psu, trancend rams, miley cyrus, justin bieber etcetc)
And by 'wrk right', I think AMD works all right when used as it is supposed to.
Anyway here's your gaming rig.
Phenom II X4 955BE @ 8K
Gigabyte 880GA UD2H @ 4.5k
2 x 2 GB kingston HyperX 1333 MHz DDR3@ 5.5 k
WD 1GB Blue @ 3K
BenQ G2220 @ 7.5K
Corsair VX550 @ not sure.
NZXT M59 @ not sure, or
CM 690 II @ 5.5
3 x 120/140 mm local fans @ 1k
Logitech basick KB @ 0.3
Gaming mouse of your choice
Gaming headgear of your choice.
Gaming mousepad of your choice.
Above mentioned CPU cooler
Noctua NH D14 @ 4.5k or
Glacialtech Alaska @ 2.3k
TOTAL = 36 something + mouse + headgear = dunno what 40k??
It leaves you around with wooping 20k for your gpu. If you are really into hardcore gaming, then allow me to go ahead and sugget you MSI 5870HD at ~22.3k.
P955 will be an excillent choice as you will be overclockin.
Also, corsair 3 x 2 GB DDR3 memory can also be bought at around 7.5-8k.
P955+5870+22" display will max out even current games till some extent.
Old 13-10-2010, 02:41 AM   #12 (permalink)
Swimming, eh??
The 5870 should get cramped up in 690 quite easily.
Old 13-10-2010, 07:07 PM   #13 (permalink)
tech geek
imsidz's Avatar
are you providing the rates of a particular area or can it b byed @ that price anywhere inside india !!
Old 13-10-2010, 07:21 PM   #14 (permalink)
tech geek
imsidz's Avatar
but the i7 870 is lga 1156 and their mobo costs within range man !! e.g. gigabyte p55 us3L
