1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:mediocre gaming, full hd viewing on a 19"-22" monitor and 32"LCD TV, internet surfing and music.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:YES
3. What is your MAX budget?
A:35k-40k
4. Planning to overclock?
A:NO
A:Win 7
A:500gb
7. What resolution will the screen run at & whats the size of the screen you want?
A:anything in my budget, looks great and is not too big.
A:7
A:no. Will select the parts and get it assembled by an assembler (plz tell trusted ones in delhi)
A:around the next month
A:YES
A:Yes Webcam
A: Delhi.Preferably NO
A:A-Z. all parts and good speakers at that.
