Old 05-10-2010, 11:49 PM   #1 (permalink)
Hmmmmm
Tenida's Avatar
Angry My XFX 8600 GT giving problem
Product-XFX GF 8600 GT 256 MB T84J256AL(G)
R.NO-8237
DATE-17/08/1010
RMA Number-13294
PART no-J6H099259
Problem-The main problem is the fan of the graphics card is not working properly.Sometimes working sometmes not.When not its tepmperature goes to above 100 degree celsius.Everytime the fan is not working i have to manually start the fan to spin with help my hand.You think this is the soluting of the problem?
I have attached the temperature picture of both the case(fan is working/fan is not working)
I have sent an email to rashi peripheral people see if they response!!!
If anyone have any suggestion kindly help me
Tenida is offline   Reply With Quote
Old 06-10-2010, 12:32 AM   #2 (permalink)
Hmmmmm
Tenida's Avatar
Default Re: My XFX 8600 GT giving problem
THE FAN IS WORKING
THE FAN IS NOT WORKING
Old 06-10-2010, 12:44 AM   #3 (permalink)
It is the famous Electric Stove Edition.
Use it to roast your bread. You can't do anything, especially with Rashi.
Old 06-10-2010, 12:55 AM   #4 (permalink)
Hmmmmm
Tenida's Avatar
hehehehehhehehe
well said
brother
Old 06-10-2010, 12:58 AM   #5 (permalink)
Hmmmmm
Tenida's Avatar
But give me solution to fight against RASHI Pheripheral
Old 06-10-2010, 01:03 AM   #6 (permalink)
Try getting the Thinkdigit people involved. Topgear had done the same: http://www.thinkdigit.com/forum/hard...ved-digit.html
Email: servicewatch at thinkdigit dot com
Old 06-10-2010, 01:17 AM   #7 (permalink)
Hmmmmm
Tenida's Avatar
ok thanks brother i will do so
Old 18-10-2010, 05:36 PM   #8 (permalink)
Update GPU driver to newer version. Nvidia driver 196.75 causes overheating issues.
CPU - Intel E5500 (800 FSB)
M/B - Gigabyte G41MT-ES2L (Ver 1.0)
Ram - 2x 2GB Kingston 1333Mhz Value Ram
PSU - Cooler Master Real Power Pro 460W
GFX - Leadtek - 9600 GT
jeetu is offline   Reply With Quote
Old 19-10-2010, 06:51 PM   #9 (permalink)
Swimming, eh??
toad_frog09's Avatar
^^^i dont think thats a correct answer. Especially when op has clearly mentioned that fans not working.
toad_frog09 is offline   Reply With Quote
Old 20-10-2010, 12:47 PM   #10 (permalink)
my precious
Gollum's Avatar
I think he should dismantle the card and clean the fan for it must be stuck with dirt and since he is not even getting warranty on the card there is no other way. Either do it himself or let the card burn due to overheating and still not get warranty.
Gollum is online now   Reply With Quote
Old 24-10-2010, 05:50 PM   #11 (permalink)
Hmmmmm
Tenida's Avatar
I have done everything you maintained above but no result.The card was in warranty but the distributed doesn't want to replace it.
Old 10-06-2011, 07:25 PM   #12 (permalink)
I had the same issue. i used a vaccum cleaner but in vain, after that when the fan spins it used to make noise, later i came to know that a capacitor has also blown, luckily i had 1 mth warranty left. i gave it rashi and got it replaced today, they gave me a different different looking 8600gt card. anyways the service center guy told me that i am a bit lucky to get it replaced and most of them are considered as damaged and they reject it.
jerrygeorge007 is offline   Reply With Quote
Old 10-06-2011, 09:40 PM   #13 (permalink)
I am the night! I am....
vickybat's Avatar
^^ Even my 8600gt went kaput facing similar problems.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline   Reply With Quote
Old 10-06-2011, 09:52 PM   #14 (permalink)
Hmmmmm
Tenida's Avatar
You're lucky that Rashi were good in your area.In kolkata they provide most pathetic after-sales support
Old 11-06-2011, 12:18 AM   #15 (permalink)
Project Halcyon V2.0
tkin's Avatar
My friend got his 8800gt alpha dog replaced just a week before it ran out of warranty, have you tried taking it to rashi first?
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 11-06-2011, 04:54 PM   #16 (permalink)
mithun_mrg's Avatar
Guys 196.75 drivers it was last year & i was playing BadCompany2 a beta driver was released which had fan controller problem after the initial reports the drivers were removed from nvidia site, But thousands of users of users were left with burnt,fried cards i think his card was the victim of that driver i was lucky because i used zotac firestorm to manage the clock & fanspeed settings of my 9800Gt here is the quote from
Nvidia
"We are aware that some customers have reported fan speed issues with
the latest 196.75 WHQL drivers on NVIDIA.com. Until we can verify and
root cause this issue, we recommend that customers stay with, or return
to 196.21 WHQL drivers. Release 196.75 drivers have been temporarily
removed from our website. "
mithun_mrg is offline   Reply With Quote
Old 13-06-2011, 11:14 AM   #17 (permalink)
even though i got my card replaced, it is not performing as good as my previous card. the looks different but its an 8600 gt , any ways i guess its time for me change my card. i'll either buy XFX ATI Radeon HD 5770 or Zotac Nvidia GTS450 or XFX ATI Radeon HD 5680.
Old 13-06-2011, 02:31 PM   #18 (permalink)
Hmmmmm
Tenida's Avatar
^^Don't go for XFX brand.Instead consider Sapphire or MSI.But don't buy ati 5770 its old card.
Old 13-06-2011, 02:37 PM   #19 (permalink)
tkin's Avatar
5770 hands down.
Old 20-06-2011, 11:46 AM   #20 (permalink)
guys, the card that rashi gave is not working, now i have to take it back to them. My budget is just under 8000 so i thought it was a good choice to go for hd 5770, can u guys suggest me any other model and brand to buy under 8k.
Old 20-06-2011, 03:56 PM   #21 (permalink)
Hmmmmm
Tenida's Avatar
Buy MSI/Sapphire- 6770 1GB
