Old 01-10-2010, 07:17 PM   #1 (permalink)
The Assassin
Cybertonic's Avatar
Exclamation Quote from SMC
People I got this quote from SMC International. The prices are great and i'm going to buy it within a week. Please suggest any changes if necessary.
1. AMD athlon ii x4 635 : Rs.5100
2. Gigabyte GA880GM UD2H : Rs.4500
3. 2*2 GB ddr3 1333MHz RAM from kingston : Rs.2100*2
4. WD caviar blue 500GB : Rs.1825
5. Cooler Master Elite 430 with SMPS. : Rs.2700
6. Wireless N compatible wireless adapter from Netgear : Rs.900
Linksys : NA
7. DVD writer from Lite-on : Rs.1000
Samsung : Rs.950
8. BenQ E2220HD : Rs.8800
9. Logitech MX518 : Rs.1450
10. Logitech Multimedia (not from smc) : Rs.500
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Moderate gaming (just fifa and maybe CoD), watching movies
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: yes
3. What is your MAX budget?
A: 30k
4. Planning to overclock?
A: yep
A: Win 7, Ubuntu
A: 500GB
7. What resolution will the screen run at & whats the size of the screen you want?
A: BenQ E2220HD (I won't go for G2220HD as i don't like its looks)
A: 8
A: Assembler
A: Within a week
A: yep
A: Graphics card, PSU, UPS
A: Delhi, I'd prefer buying from SMC only
A: I'll be buying the graphics card and PSU when amd 6xxx series is released
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 01-10-2010, 08:22 PM   #2 (permalink)
Default Re: Quote from SMC
2 changes:
1. get the Athlon II X4 630. this should cost you close to 4.5k.
2. get the cabby but not the PSU. i heard SMC selling FSP nowadays. but if you get a bottom mounted PSU based cabby, skip FSP. get Corsair or some other brand PSU.
Old 01-10-2010, 09:32 PM   #3 (permalink)
Swimming, eh??
toad_frog09's Avatar
^^^ I think a local 500w psu can handle this rig.
Atleast til end of 2010.
Altho, saga wont go too costly.
@op- just asking. What gpu would you prefer. I mean
A- new 6 series gpu in budget?
B- old 5 series gpu with dropped price.
C- nvidia card with dropped price.
Just asking cuz i too am gonna buy a new gpu later this year.
toad_frog09 is offline   Reply With Quote
Old 01-10-2010, 09:55 PM   #4 (permalink)
Cool Buddy's Avatar
I think the processor is a bit overpriced. is there any possibility of bargaining? Ram price is great. Get a good PSU if you know what kinda gfx card you'll add.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 01-10-2010, 11:29 PM   #5 (permalink)
The Assassin
Cybertonic's Avatar
I'm getting the bundled PSU for the time being. I will buy the PSU with the gfx card. My choice of gfx card will depend upon the price and performance of all the cards in the market including ati 5 series, 6 series and nvidia 4 series
Steam : $/@$]-[ DK
Old 02-10-2010, 12:55 AM   #6 (permalink)
better don't waste money here & there. also are you sure the bundled PSU (which will most probably turn out to be CM Extreme 360W) won't go up before you get a new PSU + GFX card? also are you sure that even if it blows up, don't burn your rig? if yes, go ahead. if no, hold your breath & think once before getting one.
Old 02-10-2010, 11:15 AM   #7 (permalink)
laborare est orare
Cilus's Avatar
Sam Cm Extreme 360W will be enough for it. It is not going to blow up and OP specifically mentioned that he will go for a new PSU when Graphics card is added. So not a problem right now.
CM extreme series has a bad reputation but it is not that bad really. There are lots of people who are using these PSUs to run high-end crads (one happens to be my room-mate, using a 650W CM Extreme for his GTX 285 for 1.2 Years)
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is offline   Reply With Quote
Old 02-10-2010, 11:44 AM   #8 (permalink)
Cool Buddy's Avatar
yeah, I'd say if you are sure to get a single card config, get Corsair VX 450, it will handle most single card configs till the card price of 12-13k
and AMD 6 series cards are expected to be very energy efficient, so you can't go wrong with VX450
Nokia 5230 :(
Old 02-10-2010, 12:22 PM   #9 (permalink)
yes the Extreme Power are not bad but if he goes for a new PSU & graphics card later why change PSU again & again. this doesn't makes much sense. but if the PSU do goes up, it may bring trouble for Cybertonic.
Old 02-10-2010, 03:47 PM   #10 (permalink)
The Assassin
Cybertonic's Avatar
So should i got for VX 450 or 550? The PSU should be able to handle a gtx 460 1GB in case I got for it. Using extreme power supply calculator i put capacitor aging at 30% and slightly increased a few things in case i upgrade. The result i got was 560W recommended and 510W minimum and the VX450 can deliver slightly more than the recommended wattage so should i go for VX 450?
Steam : $/@$]-[ DK
Old 02-10-2010, 04:25 PM   #11 (permalink)
XLr8
arpanmukherjee1's Avatar
bought GTX460 myself
GX 650 = 5,238 Rs
from SMC itself..
arpanmukherjee1 is offline   Reply With Quote
Old 02-10-2010, 09:39 PM   #12 (permalink)
VX450W will be a good bet. get the next higher unit "if" you planning to OC. else stick to VX450W.
Old 02-10-2010, 11:55 PM   #13 (permalink)
The Assassin
Cybertonic's Avatar
I may OC the gfx card but I'll be ocing the processor for sure to 3.2-3.4
Steam : $/@$]-[ DK
Old 02-10-2010, 11:56 PM   #14 (permalink)
The Assassin
Cybertonic's Avatar
Btw should I go for lite-on or samsung ODD?
Steam : $/@$]-[ DK
