Old 29-09-2010, 08:44 PM   #1 (permalink)
midhunmon's Avatar
Smile What is PCI-E LITE ?
What is PCIe Lite? Is it a type of PCI-E slot on the board? My new graphics card says it is XFX 250 GTS PCie Lite. Does that mean it is some kind of low grade version. Or does it only mean that it is compatible with PCI-E LITE slot?
Please reply. not much info is on the net.
midhunmon is offline   Reply With Quote
Old 29-09-2010, 09:28 PM   #2 (permalink)
Default Re: What is PCI-E LITE ?
check here. maybe your card have low bandwidth. shouldn't be a problem.
Old 29-09-2010, 09:30 PM   #3 (permalink)
clmlbx's Avatar
I don't know exactly but I believe it does mean it is compatible with pcie-e lite slot...as mother boards has pci-e lite slot which runs at x4/x8, as Pci-e slot is able to run @ x16..
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now   Reply With Quote
Old 29-09-2010, 09:44 PM   #4 (permalink)
midhunmon's Avatar
My motherboard is Intel 945GCNL and it has PCie x16 slot (not the lite version). Also in GPUz it says the card is running PCIe 16x @ x16. So i think my card is working at normal speed as it is not PCie 2.0. But my memory bandwidth is 64GB/s which is less than normal (which is 70GB/s) . But i think that is due to my memory speed being 1000MHz instead of 1100MHz. Some others who have cards with memory speed overclocked to 1310MHz has bandwidth up to 80GB/s.
I think PCIe Lite are special slots on motherboards(some yellow colored ones). It may need compatible cards and mine is one.GPUz doesn't show any other difference from other 250GTS readings.
I definitely know there are PCie Lite slots on certain Motherboards(Got info from net).
Old 29-09-2010, 11:54 PM   #5 (permalink)
Super Moderator
asingh's Avatar
PCI-E LITE has nothing to do with speed. It is the link width. PCI-E Lite slots usually only have 8 or 4 lanes available for docking.
Can you give the exact part number here.
asingh is online now   Reply With Quote
Old 30-09-2010, 07:40 AM   #6 (permalink)
midhunmon's Avatar
My Motherboard is Intel D945GCNL
Graphics Card is XFX, GS-250X-ZDFL
So pcie lite is some sort of low cost pcie slot.so my card is the full power version.it is only that it is also compatible with pcie lite slot too? It also makes sense, no one will make a card with full power and reduce its speed through its bus.
Old 30-09-2010, 11:32 AM   #7 (permalink)
Super Moderator
asingh's Avatar
Ya you are fine. You have full link.
Old 30-09-2010, 10:56 PM   #8 (permalink)
midhunmon's Avatar
Smile Re: What is PCI-E LITE ?
Thanks, Mate
