Yesterday evening i was working nicely on my PC when heavy rains with thunders started and the electricity went off. So i shut down my PC (It was working on UPS for 2-3 mins till i shut down). After an Hours when electricity came back i switched on PC but OMG it was not powering on. tried 2-3 times but no luck. So i opened the cabby. removed all connections and shorted the SMPS pins to check if it is working
(BTW its a LOCAL SMPS). It was working (at least fan was moving). So I removed the board from cabby. connected SMPS and tried shorting front panel connectors. But no luck. Tried with different SMPS, Nothing Happening. So I concluded that motherboard is dead and I gave it for repair to my friend. (BTW he is working in Digi-Link a.k.a Gigabyte Verna-Goa as service engineer for motherboards). He said he will try repairing it.
So now i have started hunting a new motherboard and of course a good PSU and I have a very tight budget
My requirements for motherboard are: It should support both AM2 and AM3 processors because for now i will be using my existing AMD Sempron LE1150 2.0Ghz AM2 processor (at least till December and then will go for higher AM3 processor say Athlon II X4 635 or so).
Also i will be using my existing 3 GB DDR2 RAM. Also i want ATI onboard graphics
Purpose of this PC is Browsing, Downloading, Office apps, Video conversion and editing etc
I have narrowed on
Gigabyte GA-MA785GM-US2H as it meets all my requirements and it is also available on
Theitwares.com Mumbai.
Also suggest a good PSU (I have shortlisted
Gigabyte SuperB 460W)
My total budget for both is Rs 6500-7000
Please suggest any other brand/model if it meets my requirements.
I am from Goa and if your suggested brand/model is not available here then I am ready to buy online
Please give your suggestions
Thank You
