Old 28-09-2010, 10:52 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default AOC LCD Monitor 2236vw i-Menu problem
I have the AOC LCD Monitor 2236vw connected to the MSI 890gxm-G65 MB onboard ATI Radeon HD4290 graphics. When I tried to control the OSD using the bundled i-Menu software, it gives "Not a plug and play monitor!". I got the following reply in this regard from AOC "support" :
I-menu is a 3rd party stand alone software. We bundle it with our product. Without I-menu, our display will still work with any PC or laptop as a plug & play monitor.
Thank you,
Romeo Ignacio,
Technical Support Dept., AOC/Envision, 47490 Seabridge Dr, Fremont CA 94538
It seems it is a software problem as Windows identifies the monitor as PnP. May be the crappy "3rd party stand alone software" is not able to communicate with the ATI Radeon HD4290 graphics?
I bought this monitor after seeing great reviews. However it is not as good as a LG or Samsung and you know how the service personnel replies from above quote! Does any body has any solutions! No hope from AOC support!
wishnew is offline   Reply With Quote
Old 28-09-2010, 12:31 PM   #2 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
Default Re: AOC LCD Monitor 2236vw i-Menu problem
I too have the same problem with i-menu on my AOC -2236vW, I think it's a problem because of some compatibility bug with Windows - 7..
But in real sense you don't even need that crappy i-menu software coz you can change any settings you want using the monitor's buttons or with your Installed Display Driver Software...
Cheers,
sid_gamer
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/132213-aoc-lcd-monitor-2236vw-i-menu-problem.html
I menu aoc - Tech / Gadgets This thread Refback 30-07-2011 05:34 AM
