Old 27-09-2010, 11:35 PM   #1 (permalink)
Default UPS Suggestion for My rig
Hi,
Please suggest me a good ups for my machine.
I have following spec:
core i7 860
4 gb DDR3 Ram
1 TB HDD
Geforce 210
650 watts smps
22 inch LG monitor
I need descent ups with backup time at least 15 minutes.My friend suggest me to go for APC UPS. but i don't know which model suitable for my PC.
Please help.
abhay2000 is offline   Reply With Quote
Old 28-09-2010, 12:45 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: UPS Suggestion for My rig
is ur SMPS (Power supply) an Active PFC type..???? if yes then go in with a UPS (i wud also recommend u APC) with a PURE SINE WAVE based UPS...
the "SMART UPS" Range of APC UPS are pure sine wave UPS..
whereas, "BACK UPS" Range of APC UPS are stepped (Modified) SIne wave) UPS (Wich u shud buy if u hv a SMPS which is a PASSIVE PFC type)
Alternatively, use this tool (from APC india website) to help u select a proper UPS wattage -----> UPS Selector Sizing Applications
CHeers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now   Reply With Quote
Old 28-09-2010, 02:37 PM   #3 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
+1 for APC UPS...
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now   Reply With Quote
Old 28-09-2010, 05:08 PM   #4 (permalink)
thanks for the reply. I don't have much knowledge of ups. as per your spec
i had visited the following site
the site had suggested me following model
APC Back-UPS RS 1000VA 230V
whats your opinion?
also me know what will be price of this model if you know
Old 29-09-2010, 12:57 PM   #5 (permalink)
hmmm..... well, u 1st and foremost need to tell me (if u knw exactly) wether u hv an ACTIVE PFC type of SMPS or a PASSIVE PFC type... smps... coz see, the simple understanding (In general) is this...
1.) IF.... u hv an ACTIVE PFC type of SMPS then go for ----> PURE SINE WAVE based UPS (Wich in APC's case) wud be the SMART UPS range of UPS (not BACK UPS range)
2.) IF... u hv a PASSIVE PFC type of SMPS then go for ----> STEPPED/MODIFIED SINE WAVE based UPS (Wich in APC's case) wud be the BACK UPS range of UPS (not SMART UPS range)
so check ur SMPS manual and then letme know...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
