Old 19-09-2010, 08:52 PM   #1 (permalink)
Default System restart bcz of adding 1.5 tb HDD
Hello friends,
I have a local cabinet with 550W SMPS + a basic m2n68AMD MOBO + AMd athlon CPU + @ gb ram + 160 GB hDD, When I Added 1.5 TB WD Caviar green internal SATA HDD on first installation it run fine, later on system started restarting frequently when i unplugged 1.5 TB hdd it started working fine where is the main problem SMPS/ or MOBO or HDD it self ? and to install WIn 7 basic AMD CPU is enough or u need quad core cpu ?
thanks
Necessity is the mother of Invention
NiluGeek is offline   Reply With Quote
Old 19-09-2010, 09:11 PM   #2 (permalink)
Default Re: System restart bcz of adding 1.5 tb HDD
Dear Nillu,
You have to check your motherboard is supporting 1.5T oR NOT from the Motherboard SPECIFICATION.
Thanks
Sachidananda Misra
misrasn is offline   Reply With Quote
Old 20-09-2010, 02:01 AM   #3 (permalink)
Techie By Heart
mavihs's Avatar
Originally Posted by NiluGeek View Post
Hello friends,
thanks
most prob its your SMPS! which brand SMPS you have?
Originally Posted by misrasn View Post
Dear Nillu,
Thanks
Sachidananda Misra
it doesn't depend on the mobo!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 20-09-2010, 06:50 AM   #4 (permalink)
Cool Buddy's Avatar
check if the sata power is working fine by changing the power cable of the existing HDD without plugging in the WD green. Try changing the SATA cable.
Most probably the motherboard is at fault coz it's an ASUS on which I face a similar problem.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 21-09-2010, 04:58 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
also you can try another sata port on the mobo to plug in the hdd.
ToPsPeEeD = FaSt BuT StEaDy
Old 22-09-2010, 06:25 PM   #6 (permalink)
Regarding SMPS it is local one which came with the cabinet, 550w
Old 22-09-2010, 06:59 PM   #7 (permalink)
^^ 550W generic PSU? get it changed. or at least get it checked with a friends PSU.
Best UPS for 1/2/3Hr. Backup for 400Watt System vishyvishy Hardware Q&A 1 30-06-2010 03:45 AM
Computer restarts GEEKCOMPUTER_GEEK Software Q&A 6 23-06-2010 02:30 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
Portable HDD + Casing Config Help knoughtyd PC Components / Configurations 6 14-11-2007 04:10 PM
A COMPLETE REVIEW: System Mechanic®7 Professional Kiran.dks QnA (read only) 29 22-01-2007 09:32 AM
