Old 15-09-2010, 09:45 PM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Default Is my system slowing down???
Ive the following config.
AMD ATHLON II X4 620 2.60GHz
Biostar TA790GXB A2+
2GB Kingston 800MHz DDR2
500GB WD BLUE
The problem is whenever i try to install Win 7 from Win XP, after booting Win 7, it takes lots of time to get installed like around more than 40min. It takes more time b/n every step like setup is installing and it's next step etc... But in my friends Desktop, it gets installed within 20min.
His Config is
Intel E8400 3GHz
1GB DDR2 RAM
Some Intel Original Board
250 Seagate HDD
Plz solve my prob...
AMD Athlon II X4 620,2GB DDR2 Kingston 800MHz,BIOSTAR TA790GXB A2+,Cooler Master Extreme Power Plus 450w,Zotac 9600GT 512MB,Dell Inspiron N5030,Creative EP 630,Sony Ericsson J105i Naite.
IronCruz is offline   Reply With Quote
Old 16-09-2010, 10:37 AM   #2 (permalink)
Wise Old Ghoul
Piyush's Avatar
Default Re: Is my system slowing down???
may be 400mhz is showing its difference
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 16-09-2010, 11:14 AM   #3 (permalink)
^^u really think 400MHz difference is the cause??But his is a quad core compared to his friend's dual core,isn't it?
ssb1551 is online now   Reply With Quote
Old 16-09-2010, 11:17 AM   #4 (permalink)
Wise Old Ghoul
Piyush's Avatar
i'm just thinking of any type of reasons
well thats was not the appropriate one
even OP has more ram
i dunno what the cause may be
--Get Backers
Old 16-09-2010, 11:27 AM   #5 (permalink)
Cool Buddy's Avatar
you sure your friend don't have 2 HDDs?
could be a problem with your HDD. Check file copy speeds in Win XP
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 16-09-2010, 06:57 PM   #6 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
I copied a 700mb video file from one drive to another. it took 26.6sec.
Is it normal?
Old 16-09-2010, 07:55 PM   #7 (permalink)
500GB WD BLUE
His Config is
Intel E8400 3GHz
1GB DDR2 RAM
250 Seagate HDD
40min for installation is normal. it took me close to 50min to install fully.
Sam is offline   Reply With Quote
Old 16-09-2010, 08:09 PM   #8 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
but it takes lot of time in between th steps. Which doesnt in my friends pc.
Old 16-09-2010, 08:24 PM   #9 (permalink)
i know. i installed Win7 on a friends lappy (Core2Duo with 3Gb ram & X4500). it completed in around 20min. though it was a upgrade.
in your case, does it takes long time for the screen to appear having to accept the license & agreement? if yes, than its perfectly ok. no problem with it.
Old 16-09-2010, 08:34 PM   #10 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
K thanx..Dude If possible PLZ reply to this thread of mine
Old 19-09-2010, 02:32 PM   #11 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Now my friend id getting same prob. When It's Extracting Windows files it takes more than 20min. Is it normal?
Old 19-09-2010, 03:13 PM   #12 (permalink)
looks to be. but what does this "extracting windows files" mean? during the installation process? if yes, last night i too went through it (updated windows as Win7 got little corrupted) and it took me 35-40min (with 4-5 restarts).
Old 20-09-2010, 11:56 PM   #13 (permalink)
Try with a freshly burned DVD.
Old 21-09-2010, 05:27 AM   #14 (permalink)
Fast 'N' Furious
topgear's Avatar
experienced this kind of prob ( on dec though ) and file extraction was failed at 98% because of bad disc - tried with another fresh copy ( disc ) of windows 7 and it installed correctly.
ToPsPeEeD = FaSt BuT StEaDy
Computer restarts GEEKCOMPUTER_GEEK Software Q&A 6 23-06-2010 02:30 PM
One Giant Command Line MetalheadGautham Open Source 23 24-05-2008 02:31 AM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
Very Strange Problem!!! shivaranjan.b QnA (read only) 1 15-06-2005 09:00 PM
