Old 13-09-2010, 04:30 PM   #1 (permalink)
change is constant!!
khmadhu's Avatar
Question motherboard for core i3
Hi ,
I am looking for a motherboard for my core i3 with lowest price.
my budget is 3.5k(max).
can anyone suggest a good motherboard within this range.. and also should be DDR 3 supportable.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 13-09-2010, 05:08 PM   #2 (permalink)
Default Re: motherboard for core i3
there is one Biostar TA785G A3 @3.7k but it shd be paired with AMD and not with intel. As for Intel the basic mobo frm Intel costs 4.6k mad for i3 proccy and these mobo is DDR3 compatible
tejaslok is offline   Reply With Quote
Old 13-09-2010, 05:08 PM   #3 (permalink)
^^ at most you can try your hands on some second hand board. Intel Original/Gigabyte/Biostar/AsRock cost 4.5-5k (minimum).
Sam is offline   Reply With Quote
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
