My PC was working fine and suddenly in the middle of working it hangs and restarts and after that there was no video and the monitor goes to standby mode. The power LED of the PC is ON. So i restarts the machine again, this time manually and now it produces 3 beeps.Then i decided to check the RAM and for it i tilted the whole cabinet and after tilting it i switched on the machine and voila, the problem is gone and the machine starts and works just fine. its like there was some kind of loose contact and after shaking the cabinet its gone.
This happens sometimes once a day , sometimes after 2-3 days.The problem is intermittent and i can't find the problem. I checked the memory with a memory testing tool(not the one which needs u to create a bootable disc, but some thing similar) and got no errors.If the hardware is damaged it should happen often, right?
I checked the event log and every time it restarts there is a log saying- "wuaueng.dll (3212) SUS20ClientDataStore: The database engine has successfully completed recovery steps".
Whats happening to my PC. i know 3 beeps are normally for memory error but if it is a memory error why does it disappear after just moving the cabinet? PLEASE Help.
My MB is Intel 945GCNL, 2 GB 667MHZ DDR2 Corsair, No Video Card(only Integrated), PSU is a cheap one(might be mercury) HDD Hitachi 160GB. Memory and HDD volume showing correctly as of now.
EDIT Now the error happened again this morning after one week of the previous appearance. This time moving the cabinet didn't work. i had to take out the RAM and put into another slot and the problem went away. after that i put the RAM in the previous slot again and the problem was not to be seen.
Is my RAM going bad or is it some loose contact. If its getting defective then why the problem appears and then disappears?
