Old 13-09-2010, 11:07 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Unhappy help needed to recover files...
Hi all,
I accidentally dropped my 40GB HDD from a height of 2.5feet.....& now
the problem is it is detected on My Computer but i cant access it...whenever
i double-click its "Drive G: is not formatted do u want to format?" but i cant format it coz i have my 17GB of data inside.can i recover it..if yes then how?
Old 13-09-2010, 11:21 AM   #2 (permalink)
Wise Old Ghoul
Piyush's Avatar
Default Re: help needed to recover files...
there is one utility by which u can recover the data even if its formated
NOTE:almost all of the guys think that formatting makes the data lost.Its not so,u can recover it by the utilities.
i dont exactly remember the name
but every company(WD/SEagate/...) have their own s/w utilities to combat this situation
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 13-09-2010, 06:41 PM   #3 (permalink)
Smile Re: help needed to recover files...
use Stellar data recovery soft they are the best in that line, i used it to recover data from FAT32 and even used it for NTFS and they worked like charm. but the recovery percentage was 82%
tejaslok is offline   Reply With Quote
Old 13-09-2010, 07:45 PM   #4 (permalink)
laborare est orare
Cilus's Avatar
instead of formatting, do a quick format. A hard disk is divided in to millions of blocks of same size, say 512 byte and all the data are divided into small blocks of 512 byte and placed in the HDD. In some specific location (specified by OS), a multilevel index is kept to access the data blocks quickly.
So theoretically if you just delete the Index, then all the data will be un-accessible as OS does not have track for data blocks. Quick-format will only delete the index, rather than the whole data.
So do a quick formatting and then use any recovery software. The chance will be increased a lot.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 14-09-2010, 09:29 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
Well the windows 7 os was not even formatting the drive....it refused......(hanged a lot)
even the DOS format didn't worked.....
so i finally tried partition wizard & to my surprise it formatted the drive nicely...now i can access the drive but lost the data.....
they say: to get some...to loose some.....
is it the best recovery tool.....
i used 3yrs back PC inspector...& it did worked @ dat time..but now i dont knw which tool is good.....
Old 14-09-2010, 04:09 PM   #6 (permalink)
himadri_sm's Avatar
Use Stellar Phoenix data recovery software.....i once recovered almost 100gb of data from a formatted HDD.
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline   Reply With Quote
Old 15-09-2010, 10:21 AM   #7 (permalink)
Wise Old Ghoul
Piyush's Avatar
but i once read un a article that quick formatting is bad
it creates the bad sectors in the disk if it not the NTFS file system
but i dunno how much is it correct
--Get Backers
Old 15-09-2010, 02:29 PM   #8 (permalink)
Electronic.
Neuron's Avatar
@ KaranTh85
Use Pandora Recovery.You will be able to recover atleast 60% of lost data.
AFAIK thats not true.Quick format won't create any bad sectors,but it won't
mask any bad sectors that are already present unlike a normal format.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 15-09-2010, 04:19 PM   #9 (permalink)
Fullbring
Zangetsu's Avatar
@Neuron: ok..i will try dat too...thanx
Old 15-09-2010, 04:57 PM   #10 (permalink)
Did you quick format ? If yes then your data is safe (99% recovery).
Else, best of luck.
Faun is offline   Reply With Quote
Old 15-09-2010, 05:04 PM   #11 (permalink)
himadri_sm's Avatar
this still holds true....just try this software..
Old 15-09-2010, 11:46 PM   #12 (permalink)
Stellar Phoenix data recovery Free or *ahem* version ?
PraKs is offline   Reply With Quote
Old 16-09-2010, 12:16 AM   #13 (permalink)
himadri_sm's Avatar
"cough" "cough"
Old 19-10-2011, 12:20 PM   #14 (permalink)
if the hard drive is not physically damaged, the chances of recovering data is big.
u can download this free data recovery software to see whether it can get some of your data back.
Bailifei is offline   Reply With Quote
Old 19-10-2011, 02:22 PM   #15 (permalink)
1 more thing Zangetsu , i am not sure what happen to ur hdd but it looks like ur partition table is corrupted (donot know how it happen by simply falling ).so try to recover ur partition table once and might be this will solve ur problem.
silicon_fusion is offline   Reply With Quote
Old 19-10-2011, 07:46 PM   #16 (permalink)
Sage of the Six Paths
Use GetBackData.
rajnusker is offline   Reply With Quote
Old 22-10-2011, 08:10 PM   #17 (permalink)
MuSiC AnD GaMiNg
you can recover data from a quick formatted drive easily by using Recuva from piriform. Its a freeware. You cannot get 100% of all files, but there are chances that you can get the files you want.
Another software which I have tried is DiskGenius. With it i was able to recover data from a formatted usb drive. You can try from here:
Download DiskGenius - Disk recovery software
Intel DH55TC Sparkle NV GF9500GT Kingston DDR3 2GB Hitachi 500GB Intel Core i3 530
nipunmaster is offline   Reply With Quote
Clean your junk files in one click with Quick Clean ritesh.techie Reviews 0 02-03-2010 03:03 PM
Some files on this volume could not be defragmented. Sarvesh Software Q&A 2 24-01-2010 08:02 PM
how to recover deleted files ?? clmlbx QnA (read only) 10 27-09-2006 05:14 PM
How To Recover Files Which is Deleted From Recyclebin too... dikudik QnA (read only) 5 04-04-2005 07:10 PM
