Old 11-09-2010, 09:48 PM   #1 (permalink)
Default HDD temperature
Speedfan shows my harddisks temperature are 43C and 44C (for both SATA hardisks) after 25 mins.
The ambient is around 26C.
Do i need to worry?
This has happened only after fixing two 120mm fans at rear and side panel.
Before that temps are 40Cand 38C.
SMPS is fixed at front side below 3.5'' drives as default (ZEBRONICS cabinet).
i have a 8400gs graphic card which have average temp of 60c.
mathikutty is offline   Reply With Quote
Old 11-09-2010, 11:44 PM   #2 (permalink)
New Gen Guru
sujoyp's Avatar
Default Re: HDD temperature
42/43 degree after 1 hr is normal and it keeps constant and wont shoot to 45/48
Its ok I think no problem...I dont have any extra fans but still get 42C
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now   Reply With Quote
Old 12-09-2010, 12:10 AM   #3 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
I have a front 120 mm fan right in front of 2 HDDs
250GB (old) - 37
500GB (new) - 34
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 12-09-2010, 05:56 AM   #4 (permalink)
Cool Buddy's Avatar
Temperatures are OK, but how did they rise after fixing the extra fans? How have you put the fans?
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 14-09-2010, 02:49 AM   #5 (permalink)
Thats my confusion
without fan temps are about 39C for both HHDs.
FAB may blow hot air on HDDs.
Old 14-09-2010, 03:13 AM   #6 (permalink)
XLr8
arpanmukherjee1's Avatar
@OP sorry. cannot create another thread.
MODS. plz look into the prob.
MY QUESTION ::>
HDD - WD 500 GB Caviar Blue
i dont know how but there was shortcircuit in the sata power of the hdd and it is damaged.
the cpu does not start when the hdd in connected.
please tell that is the data recoverable ?? i dont think the disks r damaged, only the logic board is faulty.
if not pl tell some method to recover the data. and suggest some recovery agents in new delhi.
arpanmukherjee1 is offline   Reply With Quote
Old 14-09-2010, 03:43 AM   #7 (permalink)
What a crap forum?
you cannot create threads with firebox.....................even with latest updates.
i am using chrome.........just for creating a thread.
:-PNice forum from a largest selling IT magazine.
Old 14-09-2010, 05:01 AM   #8 (permalink)
Cool Buddy's Avatar
I wanted to know the orientation of the fans. Maybe you have put fans wrongly. as a general rule, front and side fans should be inflow and rear and top fans should be outflow.
Nokia 5230 :(
Old 14-09-2010, 07:27 AM   #9 (permalink)
fan are mounted at rear and leftside of panels.
Both are 120mm fans.
Old 14-09-2010, 07:51 AM   #10 (permalink)
Cool Buddy's Avatar
are they mounted the way I said, intake on side and outflow at rear?
Nokia 5230 :(
Old 14-09-2010, 10:58 AM   #11 (permalink)
pegasus's Avatar
At 26C ambient temperature (room and not inside the case i presume), 40+ on HDDs is high imho.
What case/cabinet do you have?
Please check if you can add a fan at the front as intake to blow some air over the HDDs.
pegasus is offline   Reply With Quote
Old 14-09-2010, 11:34 AM   #12 (permalink)
Without side panel(removed) and rear panel fan working ,i noticed the HDDs temps are around 40C and 36C after an hour.
i will post the pics of the arrangement soon.
Please check the images
_________________
Athlon II X2 250 @ 3.0Ghz || ASUS M2N68-AM PLUS || 3GB DDR2 RAM || 2X500Gb GB Seagate HDD|| MSI 8400GS 512MB || FSP Saga II 400W || LG DVD RW || ACER 20 INCH Wide
Old 16-09-2010, 01:08 PM   #13 (permalink)
pegasus's Avatar
Is that a single 80mm fan at the back?
Your overall system temps maybe quite high too.
40 GB HDD on P3 amit58414 Hardware Q&A 0 03-07-2010 12:42 AM
Motherboard Temperature warnings!!!!! coolguy12374 Hardware Q&A 5 15-06-2010 09:12 PM
Temperature is shooting up.... Help me guyz... giprabu Hardware Q&A 8 10-06-2010 06:58 AM
Ext. HDD Problem sky90 Chit-Chat 4 29-05-2010 11:54 AM
