Old 11-09-2010, 07:42 PM   #1 (permalink)
Default which brand is good in mumbai for spike guard ?
which brand is good in mumbai for spike guard ? I need to buy one ASAP.
noob is offline   Reply With Quote
Old 13-09-2010, 04:42 PM   #2 (permalink)
pegasus's Avatar
Default Re: which brand is good in mumbai for spike guard ?
MX(beware of fakes), Belkin, APC?
pegasus is offline   Reply With Quote
Old 13-09-2010, 07:41 PM   #3 (permalink)
Cool Buddy's Avatar
Right time, I was thinking of buying Belkin. Is it the right choice? reputed brand it is.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 13-09-2010, 10:48 PM   #4 (permalink)
RaptorX's Avatar
A couple of weeks ago my old spike guard (generic) started making crackling sounds. Since I needed a replacement urgently I bought an MX one from a nearby shop instead of going to Lamington for a Belkin one. The Mx spike guard is working fine so far.
From what I've heard Belkin is the best. Mx is not a bad 2nd option.
Surge Protector
Take a look at these topics:
Link 1
Link 2
Btw Pegasus- How would one check if it's a fake one?
RaptorX is offline   Reply With Quote
Old 13-09-2010, 11:56 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
I would also voter for Belkin. I use one its gr8. Previously my UPS used to be switched off though there is power and other spike related issue.
Lost MOBO due to that and SMPS.
Now I use Belkin and the UPS related problem is gone.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Old 14-09-2010, 05:09 AM   #6 (permalink)
Cool Buddy's Avatar
Belkin 4 pin @ Rs. 440 and economy series 6 pin @ Rs. 600. (prices include tax). Well priced I suppose.
Primeabgb lists the 6 pin one for Rs. 500, but shipping charge of Rs. 150 will make it 650 for me.
Nokia 5230 :(
Old 14-09-2010, 11:25 AM   #7 (permalink)
pegasus's Avatar
Surge Protector
Link 1
Link 2
I am not sure how to spot fakes.
There was an old thread on TE or somewhere i think, by a very knowledgeable person.
Bt here is another discussion i could dig up for now>
http://www.techenclave.com/pc-periph...p-94502-2.html
The only way for me not to end up with a fake one now may be by buying it from some reputed store and taking a cash memo for the same.
(Champion Rubber at Lamington Road used to be the authorised reseller for MX products since a very long time iirc)
Belkin products, especially the higher series look well-finished for sure.
Their gold and superior models supposedly provide warranty over any connected equipments upto a certain amount as per the series.
But not sure if they are the best per se.
APC too had some good surge protectors but pricing and availability here i am not sure of.
MX ones are just about ok for the price they sell at- though cable quality, switches etc could have been a better i feel.
At least they are not as bad as the 100-200 ones of various names.
They used to come with 6-months warranty iirc.
A 6-socket with indivdal switches had costed me roughly Rs.400/- a few years back and worked fine till i gave it away.
MX ones also have those 3 LEDs that indicate if the voltage from the source/socket is ok or not.
Old 14-09-2010, 02:31 PM   #8 (permalink)
Is there any Belkin spike guard with 1 switch for 1 plug.
I dont need which has 6 plugs with 1 switch.. I am looking for 6 plugs which 6 switches so each device can be used only when required.
PraKs is offline   Reply With Quote
Old 14-09-2010, 03:53 PM   #9 (permalink)
Cool G5's Avatar
Post Re: which brand is good in mumbai for spike guard ?
That's the reason I opted for a local brand. It is rugged in built & has a switch for each socket. Also the socket is the standard one found in India & so the plugs fit in tightly.
Cool G5 is offline   Reply With Quote
Old 14-09-2010, 10:35 PM   #10 (permalink)
@Cool G5
Which brand was it ? IS it good & pls give price.
Old 14-09-2010, 11:25 PM   #11 (permalink)
Cool Buddy's Avatar
I also wanted each socket with a switch, but with local brands, it's hard to tell whether good or bad, better go with a trusted brand. I was shown one with for Rs. 225, but wanted to buy a good one after the last one showed the fireworks. So didn't buy it
Nokia 5230 :(
Old 15-09-2010, 11:12 AM   #12 (permalink)
Cool G5's Avatar
@Cool G5
Brand name is Om Sejnath. It has 4 sockets with individual switches & I bought it for Rs.250/- Been using it for 3 years for now with no problems at all.
Old 15-09-2010, 03:03 PM   #13 (permalink)
@Cool Buddy
Let me know if you come across any standard brand, I am also looking for one.
@Cool G5
Thank you. I guess that brand is available only in Mumbai, Never heard of it
Old 15-09-2010, 03:13 PM   #14 (permalink)
himadri_sm's Avatar
Buy an MX spike guard...it comes with individual switches for both 4 & 6 socket variants....the mumbai price(lamington street) for a six socket individual switch spike guard is around Rs.500/-..i've been using one since the last 14 months & never had any problems woth it..
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline   Reply With Quote
Old 15-09-2010, 04:55 PM   #15 (permalink)
Cool Buddy's Avatar
MX spike guard website doesn't show anything in Kolkata, so it's belking for me.
@PraKs
I would have already bought belkin, but the shop that quoted lowest prices didn't have it in stock, asked me to come after 2 days. I'll buy tomorrow.
Nokia 5230 :(
Old 15-09-2010, 10:15 PM   #16 (permalink)
Cool G5's Avatar
Even a friend of mine uses the 6 socket one for a year now. Its great & he is having no hassles. If you're good at bargaining then you can get it for lower price.
Old 15-09-2010, 11:45 PM   #17 (permalink)
OH man, What a site they have.. Better then belkin too.
Mumbai based company but amazing products
Here are few spikes...
MDR Electronics - MX Electronics - Home Theater Cables & Connectors - Computers & Laptop Accessories - Pro Audio / Studio Audio Cables & Connectors - Audio Video Components & Accessories - Fiber Optic Component & Accessories - Cable TV Component & Ac
Which one u have G5 ?
Old 16-09-2010, 11:56 AM   #18 (permalink)
Cool G5's Avatar
My friend has one having 6 sockets alonwith 6 individual switches. Its not there in the links you have posted. Might be a duplicate one but its working great. It has green switches with orange LED's underneath them.
Old 16-09-2010, 05:32 PM   #19 (permalink)
They have just so many.
Not able to select... Need 4-5 plugs with 4-5 switches.
Can you recommend some ?
Old 16-09-2010, 06:49 PM   #20 (permalink)
himadri_sm's Avatar
this is the one i have- LINK
this also seems good- LINK
Old 16-09-2010, 08:40 PM   #21 (permalink)
Cool G5's Avatar
This(1st link) was the one I was talking about.
Old 16-09-2010, 10:59 PM   #22 (permalink)
Cool Buddy's Avatar
Bought Belkin 4 pin for 495/-. Plugs fit in good, from thinnest speaker plugs to the fattest Monitor plugs, all fit in well. Feels well built too.
Here's a long story cut short:
Shop 1: I ask, he replies - belkin 4 pin for Rs. 475+tax. I leave
Shop 2: I ask, he replies - belkin 4 pin for Rs. 450+tax. I think, then I leave
Shop 3: I ask, he replies - belkin 4 pin for Rs. 425+tax. I ask for it but is out of stock. Asks me to come after 2 days
After 2 days:
Shop 3: I ask, he replies - belkin 4 pin for Rs. 425+tax, but is out of stock
Shop 2: I ask, he replies - belkin 4 pin for Rs. 450+tax. I ask for it, but is out of stock
Shop 1: I ask, he replies - belkin 4 pin for Rs. 475+tax. Finally I buy it for Rs. 495
I figured either its 500 bucks or its not for me. So bought it.
Nokia 5230 :(
Old 16-09-2010, 11:27 PM   #23 (permalink)
Can you please tell which is good ? Both looks good
I am fine with 4 pin one.
Old 17-09-2010, 12:56 AM   #24 (permalink)
himadri_sm's Avatar
i have only used the 1st one so can vouch for that...but i am not sure of the second one..you should ask sam.shab here....he can tell you better...BTW, if individual switches is not a necessity, you may go for belkin..after all it has a reputation..
Old 17-09-2010, 10:51 AM   #25 (permalink)
individual switches are must.
NO use powering on Home theater when watching normal TV.. So Its required.
@sam.shab, give your inputs pls
Old 19-09-2010, 02:15 AM   #26 (permalink)
Point Blanc
I am using a spike guard from some company named "WOW", IMO it is very good doesnt gets heated up much. It has separate fuse and on/off switch for each pin and has 5 pin, spent 350 bucks for it. Amps value for each fuse is 10A and plastic quality is good.
Belkin or APC or Cona(very popular electricals company) cost more but no individual fuse and switch, as praks said they are a must, you cannot go without them if you really want good spike guard.
@praks first one is better check the amps rating for the fuse used in second it is 6A which is low.
acewin is offline   Reply With Quote
Samsung Champ - Any good? Panchu Mobiles and Tablets 14 14-10-2010 11:21 AM
good dth service? tgpraveen Chit-Chat 18 06-06-2010 08:35 PM
