Old 10-09-2010, 09:22 PM   #1 (permalink)
Exclamation Need suggetionnn
I m a student of Mechanical engg. and had to work with CAD softwares, recently i m going through a CFD(computational fluid dynamics) course. I thinking of buying a laptop ranging from 60 to 70k. I m goin to use it ,mainly for CAD and gaming, so i need suggestions regarding a compatible laptop or notebook for CAD. im thinking about alienware m15x but it seems costlyy..!!!
please help
. suggest
imhemant is offline   Reply With Quote
Old 10-09-2010, 10:31 PM   #2 (permalink)
Default Re: Need suggetionnn
If U want to run heavy software and latest games ...
Better opt for a desktop rather than a laptop ...
Desktops can do stuff laptops of the same price range can`t ...
Thats what I personally feel ...
Let the senior members post their valuable suggestions ....
vizkid2005 is offline   Reply With Quote
Old 10-09-2010, 10:42 PM   #3 (permalink)
Anish's Avatar
If u really want a laptop for your mentioned needs.... go for dell studio series or sony vaio series... the best within your budget
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 10-09-2010, 10:48 PM   #4 (permalink)
Joker
Posts: n/a
only a desktop pc would do justice to your requirement
Old 11-09-2010, 12:05 AM   #5 (permalink)
please help
. suggest
don't waste money on a lappy. the apps you mentioned are too demanding & will need a high end lappy. 60-70k will at most fetch you a moderate gaming lappy, not a heavy duty, pro work ready one. get a desktop. though i feel even for a desktop you need over 80k to be profitable still a desktop will atleast make more sense.
Sam is offline   Reply With Quote
Old 11-09-2010, 11:24 AM   #6 (permalink)
Thats Xactly wat I meant to say ...
Old 11-09-2010, 11:42 AM   #7 (permalink)
Passionate
jayantr7's Avatar
Strictly speaking
In the budget of rs.60,000[cpu-assembled] you can get a better pc than any other laptop built in the world.....
But if you want a laptop then go for Dell Studio or Precision or HP ones.
Digitally Impulsed
jayantr7 is offline   Reply With Quote
Old 11-09-2010, 07:04 PM   #8 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
fluid dynamics need a better graphics cards- which no lappy will provide you (upto 80 k)or u will stuck when u play them in ur viewport,
better get a desktop and get the gtx 460 or ati 5870 (check the frame rate option in display-ui setting-framerate( in maya , nt sure if it is same in autocad) of ur current gpu.
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
