10-09-2010, 02:08 PM
Suggest a proccy & mobo
Hi frens i need help to buy a new processor and motherboard. I have following componets and i dont want to change anything except proccy & mobo.
AOC 22 inch Full HD Lcd
Corsair 1*2 gb ddr2 667mhz ram
CoolerMaster 600 watts psu
xfx 8800gt alpha dog edition gfx.
So now i want a good proccy and mobo combo which does justice to these components. My budget is 9000. Pls help me guys i want to buy as soon as possible. Thanks in advance.
10-09-2010, 02:21 PM
Re: Suggest a proccy & mobo
Gigabyte GA-MA78GM-US2H @ 3.9k (780G chipset + AM3 CPU ready)
AMD Athlon II X4 635 2.9Ghz @ 5k
10-09-2010, 02:35 PM
Thanx for the reply. Is that processor better than the phenom ll 550?
10-09-2010, 02:42 PM
For gaming, Phenom II X2 555 BE is the way to go because of it's 6MB L3 cache. But for multi-threaded and rendering tasks, Athlon II X4 635 is better. The choice is yours.
10-09-2010, 02:54 PM
Ok then i think i will go with phenom 555 BE. Is there any other good alternative for mobo?? I think i can stretch my budget to 500 bucks more. So which is the best mobo for 4500?
10-09-2010, 03:16 PM
get Athlon II X4 630 + Gigabyte GA-MA785GM-US2H. expect total cost to be around 9k. you can instead get the Phenom II X2 555 BE & try unlock the extra 2 cores but its a luck thing. so don't expect 100% success.
10-09-2010, 03:29 PM
What about the memory? Does the combo support ddr2 @ 667mhz?? I dont want to change the ram. I bought it very recently.
10-09-2010, 04:09 PM
^^ the board suggested by ICO as well as me are AM2+ board. will support DDR2 ram. processor is AM3. so will work in AM2+ board & support both DDR2 as well as DDR3 (in case you change motherboard in future, can use DDR3 supporting board).
10-09-2010, 04:25 PM
And one last question. How many ram slots are there in that board? 2 or 4?
10-09-2010, 06:40 PM
4 RAM slots.
14-09-2010, 11:03 AM
hi guys dunno if this thread is still active but I got a query on this.
3 other MoBos which are Biostar A780L3,Biostar MCP6P3,MSI GF615M-P33 also support AM3 n 800Mhz memory.So can 1 go for AMD Athlon II X4 635/630 with one of the afore-mentioned MoBos with an existing DDR2 800Mhz memory?
14-09-2010, 11:30 AM
laborare est orare
Try to avoid AMD 780 G chipset based boards as they don't support some advance properties like Advance Clock Calibration (ACC), smart overclocking etc. They were designed for the old AMD AM2+ processors and support new Athlon II/Phenom II processors by BIOS update. So don't expect to get the max performance.
Get 790 or 785G based chipset boards. My suggestion will be
BIOSTAR TA785GE 128M AMD 785G SB710 @ 3.54k (here is the link)
The basic features are
AMD 785G Chipset with SB710
Supports All Phenom II and Athlon II CPUs (125W)
ATI HD 4200 128 MB DDR3 Side port memory with max 512 MB shared
4 Ram slots with max 16 GB support
1 DVI and one VGA output
1 PCI Express X16
2 PCI
6 SATA II
10 USB 2.0
Realtech Gigabit LAN
Realtech 5.1 Channel HD audio
For processor, go for AMD Athlon II 635 as other suggested.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
14-09-2010, 11:38 AM
1 PCI Express X16
2 PCI
6 SATA II
10 USB 2.0
nice suggestion!!But will BIOSTAR TA785GE support DDR3 1333 memory if one wishes to upgrade the memory in future?
14-09-2010, 12:04 PM
laborare est orare
No, it does not support DDR3 ram, it is a DDR2 based mobo. You can add as many DDR2 modules until it reaches 16 GB but if you want DDR3 ram to be added, then you need to change the motherboard. And if you are going to get a DDR3 mobo for now, then you have to sell your current ram, which is not a very good idea for now, as both AMD and Intel are releasing their new gen processors at the end of this year.
15-09-2010, 12:15 PM
what abt Biostar MCP6P3?Is it a good MoBo?
15-09-2010, 02:49 PM
That bioscctar mobo looks good for the price. I have already ordered the gigabyte mobo for 4k. I think i should have waited lil longer before ordering.
15-09-2010, 03:16 PM
won't recommend this board. its based on Nvidia chipset. best is to go with AMD chipset.
15-09-2010, 07:36 PM
hey wats the difference between Nvidia n AMD chipset?I mean wat all properties make AMD chipset superior to nVIDIA chipset?
15-09-2010, 09:57 PM
#19 (permalink)
AMD chipset for AMD processor:
1. Graphics. AMD IGP (the current 8 series or 7 series far better than Nvidia 6-7 series IGP).
2. HT link. AMD Hyper Transport link runs at 1.0 maybe for Nvidia but runs at 3.0 for AMD chipset (take it as higher HT link, better performance).
3. Cool&Quite. the board you linked have Cool&Quite on but the earlier Nvidia chipset doesn't have it. so do ACC & a few more important features. also theres a big question mark about the future processor support on Nvidia chipset boards.
16-09-2010, 11:17 AM
#20 (permalink)
^^hmmm..I didn't know that..which would be a good AMD based chipset MoBo within 4K?
16-09-2010, 11:18 AM
#21 (permalink)
Wise Old Ghoul
^^biostar to look for
16-09-2010, 11:53 AM
#22 (permalink)
no. htlink for nvidia 980a, 780a sli chipset is also ht 3.0.
16-09-2010, 03:24 PM
#23 (permalink)
Sam sir- Which model/s are you talking about?
Please give some links for both, ones that run at 1.0.
Please give links for nvidia chipset model/s that didn't have cool&quiet?
16-09-2010, 06:54 PM
#24 (permalink)
thanks for the info
link i need to search. most probably it was the AM2+ version. the AM3 version all have HT 3.0 (yesterday i know that Nvidia launched AM3 version of their chipset too). But yes, 1 good example is the Gigabyte 740G (AM3) board which have HT 3.0 but run only at 1.0 when used with AM3 proccy (strange). will Google up a bit if these AM3 board run the proccy at HT 3.0 or HT 1.0.
will search it. all these features were not in AM2+ board. AM3 brought many new features.
16-09-2010, 07:07 PM
#25 (permalink)
ahem sam, that question is not asked by me. the last of your quote!!
16-09-2010, 07:35 PM
#26 (permalink)
DAMN !!! thanks yaar. corrected
