Old 09-09-2010, 01:52 AM   #1 (permalink)
Default Please sugggest
i want to upgrade to 5.1 speakers from my creative inspire 2.1 so which 1 should i buy...
i have these options...
logitech x540, logitech z506(doesnt have a wired remote also) creative t6200, edifier m3500 or any other model suggested by u ppl in 5-6k budget.
thanks in advance...
anyone is active on this forums please reply its urgent
jayvyas is offline   Reply With Quote
Old 11-09-2010, 04:24 PM   #2 (permalink)
Joker
Posts: n/a
Default Re: Please sugggest
both logitech x540 and z506 are equally good...but the former is discontinued...go for x540 if you can find it.
Old 11-09-2010, 05:23 PM   #3 (permalink)
Cool Buddy's Avatar
don't wanna, but can't help it. A little grammar lesson. When you say the former is dicontinued, it refers to the x540, you should say the latter is discontinued.
Sorry to be off topic
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 12-09-2010, 11:40 PM   #4 (permalink)
ya i no x540 is discontonued and main problem with z506 is its controls r on the speaker dat means if i place the speaker on the topper side i need to reach there to increase or decrease volume (ill try to find if i get x540)
how bout creative t6200, edifier m3500... or any other model u people suggest??
Old 15-09-2010, 02:12 AM   #5 (permalink)
anybody der???
Sugggest me some games n.regmi Gamerz 14 10-06-2006 03:49 AM
