LinkBack (2) Thread Tools Display Modes
Old 08-09-2010, 11:51 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Default DDR 800Mhz Dual Channel Memory running at lower Mhz
Can any1 pls explain why my DDR 800 Mhz dual channel memory is running at 667 Mhz only ? and how can i fix it
System info
Core2Duo E7500
Gfx 9400GT
400W power supply
4Gb ram DDR800
MB Website :Here
thanks in advance
Rajesh345 is offline   Reply With Quote
Old 09-09-2010, 12:26 AM   #2 (permalink)
Default Re: DDR 800Mhz Dual Channel Memory running at lower Mhz
Some possibilities:
1. You have the memory clock manually set at 333/667 in BIOS.
2. The RAMs are 667 types. In the days of DDR1, I encountered some Zion RAMs that were labeled as DDR400 but were actually DDR333. Some were detected by the mobo as DDR400 but could not run stably at that speed. The clock had to be set manually for DDR333 (basic clock 166). Others were labeled DDR400 but were detected as DDR333.
Does it happen only in dual-channel mode? What happens when you install only one stick?
pimpom is offline   Reply With Quote
Old 09-09-2010, 12:54 AM   #3 (permalink)
Only option in bios is to select timing manually(CAS , RAS etc)
[I am afraid to change cas , ras timings ]
Does it happen only in dual-channel mode? What happens when you install only one stick?[/QUOTE]
nop , when running with 1 stick it is showing as 800mhz
Old 09-09-2010, 12:55 AM   #4 (permalink)
Tech.Masti's Avatar
^what happens with single stick?
Tech.Masti is offline   Reply With Quote
Old 09-09-2010, 12:56 AM   #5 (permalink)
showing as 800 mhz
Does this have anything to do with Different timing?(CAS, RAS etc)
Old 21-09-2010, 09:13 AM   #6 (permalink)
I found option in bios "Dram Freq " current it is set to Auto
there is option to set 667 /800/1066
if i manually set it to 800 will it cause any problem to my system or ram?
pls:chk pics in 1st post for more info abt my MB , i can upload more pics abt my system spec if u want
thanks
Old 01-10-2010, 04:16 PM   #7 (permalink)
pegasus's Avatar
Maybe due to mismatched sticks?
The SPD data on both varies a lot.
One stick is rated DDR2 800 at 5-5-5-18 and one is rated DDR2 800 at 6-6-6-18 as in the cpuz screenies.
Please set the RAM speed and timings manually and check.
Set it at 800Mhz and 6-6-6-18 and check for stability.
You may also try running both sticks at 800Mhz, 5-5-5-18 but it is very strongly recommended to test stability before you settle for tighter timings as one or both sticks in pair may not be able to do that.
pegasus is offline   Reply With Quote
Old 02-10-2010, 11:31 AM   #8 (permalink)
i set ram freq to 800 mhz in bios
found no stablity problem
http://img9.imageshack.us/img9/9779/ramcs.jpg
Cpu z is telling Dram:Fsp ratio is 2:3 i heard 1:1 ratio is better(google search) is that true ? my bios have no option to set fsp: ram ratio , or is it ok ?
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/131538-ddr-800mhz-dual-channel-memory-running-lower-mhz.html
Chip.in • View topic - VGA or DVI ? This thread Refback 12-10-2010 04:10 PM
Chip.in • View topic - VGA or DVI ? This thread Refback 04-10-2010 11:33 AM
Latest Hardware Prices & Quotes..!! suave_guy Hardware Q&A 5604 14-03-2011 02:05 PM
System Overlocking. upendra_gp QnA (read only) 7 18-05-2005 03:26 AM
Help Req For Motherboard PraKs CPU / Motherboards 11 24-11-2004 05:42 AM
Dual channel memory android QnA (read only) 1 24-10-2004 12:19 AM
