Hello Guyz !!!
Please help me by suggesting appropriate motherboard and RAM for my new rig !!!!
i7 950
Corsair HX850
GTX 460(1 gb) * 2
500 GB HDD
CoolerMaster 430 Elite
Please suggest a motherboard that is suited and available(Mumbai) for my needs :
3 way SLI not needed ...
SATA III and Usb 3.0 not needed
( Will get an add-on card later .. But will the SATA III on the card will be as good as SATA III on mobo) ????
Will I need to overclock in next 3-4 years to play future games even with 2*GTX 460(1 gb) ???
If yes .. please suggest mobo with overclocking ability ..
Brand preffered : ASUS
Considering RAM suggestions ...
What is
latency, ppl keep talking about ??? How does it affect my PC`s performance ???
Considering 2*GTX 460(1 gb) ... Will I need more than Corsair (3*1 gb ) Kit tp play future 3-4 yr games ?????
If yes please suggest RAM also ....
What difference does 1600 MHz and 1033 MHz RAM make ???
Does 1600 Mhz RAM have compatibility issues with motherboard ????
Like will it run only on specific motherboards ???
Please enlighten me with your valuable suggestions ....
Thank You !!!
