Old 08-09-2010, 10:19 AM   #1 (permalink)
blademast3r's Avatar
Default Help me choose an atom based netbook
Hey guys
I currently own a laptop , but i need to carry it regularly so i thought i'd go for a netbook.
First off.. Is a netbook enough to run and compile x86 codes using vc++??
The factors im looking at are
1)Battery life
2)2GB RAM
3)Good durable design as I'll be carrying it around regularly.
4)Price of around 20k
So what are my options?
Also how much would i get for old acer aspire 4710 lappy??
blademast3r is offline   Reply With Quote
Old 08-09-2010, 11:08 AM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Help me choose an atom based netbook
Well, within 20k, it is very hard to find a Net-book with 2 GB DDR3 ram. You have to increase your budget to 1 or 2k. I have two choice for you.
My Recommendation is
HP Mini 210-1117TU
The configuration is
Atom 450,
10.1" HD LED Display,
2GB DDR2,
320GB, Audio:Generic,Stereo,
Speakers:Generic,Stereo,
802.11b/g Lan,
WiFi,
Webcam with Integrated Digital Microphone,
93% Full size island-style keyboard,
Bluetooth, 6 Cell,
Win 7 Starter,
Size:268 mm X 178 mm X 22.9 mm
Price is around 21.7k. The Atom processor present in this machine is the latest gen processor, having GPU and PCI Express bus integrated in the CPU, resulting very less power requirement.
Alternatively, you can also go for
Lenovo 59 045023 Netbook (Atom 1GB 160GB)
Intel Atom Processor N475 (512K Cache, 1.83 GHz),
1G DDR3 (667MHz),
160G (9.5mm, 5400rpm),
Intel GMA 3150 Graphics,
LAN,
BCM 4313 BGN,
Bluetooth 2.1,
Camera 1.3M,
4-in-1 card reader,
Black,
6Cell 2.2A Battery,
Free DOS, Black Color,
10.1 SD LED Glare
Price 17k
You can add another one GB DDR3 ram @ 2k (max) to make it a 2 GB one and still within your 20k budget. It is little better as it is having DDR3 ram and 1.83 GHz processor, compared to the 1.66GHz processor, present in most of the laptops.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 08-09-2010, 11:31 AM   #3 (permalink)
montsa007's Avatar
U Can Upgrade Netbooks :-s?
montsa007 is offline   Reply With Quote
Old 08-09-2010, 11:57 AM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
netbooks cannot be upgraded..
to the OP: another option wud be netbooks from
ASUS 1005px -- Rs. 15.5K,
MSi u100 -- Rs. 14k,
Acer D260 -- Rs. 16.2k
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline   Reply With Quote
Old 08-09-2010, 12:23 PM   #5 (permalink)
Thanks Clius! Will take a look at lenovo.. So u say 1.66GHZ atom 450 2GB ram is slower than a 1.83GHZ atom 475 with 1GB ddr3??
Also can someone clarify if visual studio 2008 runs fine on an atom?
Old 08-09-2010, 12:27 PM   #6 (permalink)
Techie By Heart
mavihs's Avatar
if your not in a hurry wait till fusion arrives!
VS will run but will be slow in compiling!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 08-09-2010, 12:34 PM   #7 (permalink)
Fusion is meant to integrate the GPU with ur CPU rite? I dont care abt graphics for my netbook. For that I have a phenom and HD5770 powered gaming rig
Old 08-09-2010, 02:39 PM   #8 (permalink)
laborare est orare
Cilus's Avatar
1st of all, the RAM of a netbook can be upgraded easily. Do a little Google and you will find thousands of ways to upgrade the ram. The laptop, I have suggested, in their specification it is clearly mentioned that they are upgradable up to 2 GB.
Ask the vendor, from whom you are buying the laptop, to increase the RAm.
Old 08-09-2010, 06:22 PM   #9 (permalink)
hmmm...cool.. Is it really worth going for netbook? The only attractive feature for me is light weight and battery life.. Is is THAT slow?
Old 08-09-2010, 10:52 PM   #10 (permalink)
The Assassin
Cybertonic's Avatar
search for a single core pentium 4 PC and do your work on it. You will get a rough idea about a netbooks performance.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 09-09-2010, 09:35 AM   #11 (permalink)
Techie By Heart
mavihs's Avatar
its not all about the GPU, its also about a much better CPU then the Atom with better power consumption!
Old 09-09-2010, 10:55 AM   #12 (permalink)
Therapist's Avatar
Not really. You can upgrade them with their Mini PCI-E expansion slots, this is excluding Lenovo and Sony products, which have locked these slots. I bought a HP Mini 110 with an HD screen and purchased a Broadcom Crystal HD (Mini PCI-E) decoder for Rs 1000 shipped off Ebay (Hong Kong). I can now run 10GB+ Full-HD (1080p) m2ts and MKV movies liquid smooth with just over 10% CPU utilisation.
By the way, netbooks with dual core Atom 550 processors are out elsewhere in the first world. Makes sense to wait for the same.
Compiling isn't recommended with the Atom processor. It took me an inordinately long time (several hours) to compile the source code of a custom XBMC build integrating Crystal HD support on Ubuntu. But it's awesome as a download rig, for entertainment, work and websurfing.
Samsung P2370MS | Phenom II 555BE | MSI 790GX | 4GB Corsair XMS3 DDR3 1600 | CM Hyper 212+ | Sapphire HD 4850 (1GB) | Corsair CX400 | NZXT Gamma + Sentry2 fan controller | Razer Abyssus + Rantopad H3
Therapist is offline   Reply With Quote
Old 09-09-2010, 01:42 PM   #13 (permalink)
Try to find a Toshiba T235D-S1340 instead of going for a Netbook. It should be priced around 23k.
Here are the specs: http://laptops.toshiba.com/laptops/s...30/T235D-S1340
Old 11-09-2010, 10:37 PM   #14 (permalink)
Chetan1991's Avatar
My roomy also wants to buy a netbook under 20k (from Mumbai), so more replies are welcome.
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline   Reply With Quote
Old 12-09-2010, 09:10 AM   #15 (permalink)
Adam young
sukesh1090's Avatar
what is this fusion?............
sukesh1090 is offline   Reply With Quote
Old 12-09-2010, 07:17 PM   #16 (permalink)
im also thinking abt gettin a netbook my budget is around 16 k to 17 k and i dont need windows as i already have 3 genuine OS, will boot that so any thing except Acer will do! will wait for replies ty
tejaslok is offline   Reply With Quote
Old 13-09-2010, 11:24 PM   #17 (permalink)
When are dual core atom proccy netbooks set to make an entry to indian market?
overclocking atom n450 sukesh1090 Overclocking 5 19-08-2010 12:08 PM
Need help to choose language for developing DBMS application kumarrohit007 Programming 15 16-06-2010 03:08 PM
Free Webinar - Intel Software Network - Netbook Apps Development srinivas.vk Programming 0 13-05-2010 08:10 PM
Intel's Linux based Meego OS celldweller1591 Random News 0 23-04-2010 07:10 PM
Help me on Selecting a Netbook surenther.ss Hardware Q&A 0 27-01-2010 08:53 AM
