View Poll Results: Which Laptop out of below 3
ACER 5740 G 2 66.67%
Sony Vaio E Series - VPCEB16FG 0 0%
HP Pavilion dv6-3057tx 1 33.33%
Voters: 3. You may not vote on this poll
Old 07-09-2010, 07:54 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Gaming Laptop under 55K
Hi All,
I have shortlisted below 3 models for my requirement.
All of them have 1 GB HD 5650 graphics card and Core i3 processor. Other things don't matter much to me.
1. ACER 5740 G
2. Sony Vaio E Series - VPCEB16FG
3. HP Pavilion dv6-3057tx
I need to decide upon:
1. Build Quality - I need to keep the laptop in good working condition for at least 3 years.
2. After sales service
I have added a poll for the same as well.
Please help me in making a good decision
Thanks,
Rohit
professorsingh is offline   Reply With Quote
Old 07-09-2010, 11:25 PM   #2 (permalink)
Default Re: Gaming Laptop under 55K
Acer generally has build quality issues, so avoid it.
Get anyone of the other two depending on your preference.
Old 08-09-2010, 12:13 AM   #3 (permalink)
laborare est orare
Cilus's Avatar
My choice is Acer 5740G as I have the opportunity to get a hands-on on this Laptop. After my suggestion, two of my friends have bought this laptop.
It has a good build quality and very good battery life. For normal work, it provides over 3 Hrs, and even when watching 720P HD contents, it gives more than 2 Hrs backup. In games, it is better than the all the above mentioned counter parts because of the Core i5 processor. I personally tested it with Crysis, Dragon Age Origin, COD6, Mafia 2, Mass Effect 1 and 2 and all the games are playable (>= 30fps) with everything set to highest. Even Crysis gives average 30-32 fps with 4X antialising and everything set to highest.
If you want external review, go to AnandTech or NotebookCheck. They has chosen it as the best budget gaming laptop.
The downside is the display. It is not as good as Dell. But by adjusting setting from Catalyst Control Center, you can get a better looking display.
Other thing is the on board Sound box. It is in little lower side. But plug a good headphone, you will be pleased to hear the sound.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 08-09-2010, 12:18 AM   #4 (permalink)
Thanks ico for your opinion. Do you have some personal experience with ACER?
Actually, I had acer around 2 years back and it didn't perform well, but my friend's ACER worked really well for 3 years at least. So, I am not sure if it is all luck
Also, general reviews about this ACER model are very good, but since it is only a few months of its launch we can't comment about its quality.
I am looking for generic quality, build of ACER, HP, Sony laptops - and customer support - as all have almost same config - and within range of 3-4k give or take (that I can afford) - but I need a piece which will last long, and if in case of problems I will get good customer service.
Please suggest.
Thanks,
Rohit
Thanks Cilus for detailed info. I read Anandtech and couple of other reviews, everyone is very pleased with the performance.
Problem with HP and Sony reviews is that they don't have same model (both number and config) built for India and outside - so we don't generally get exact review of the model that we are looking for
General reviews about Sony Vaio are good as well including the looks, full HD and built - but I heard its battery performance is bad and also it heats a bit more.
HP is overall good - one good thing is it is offering 7200RPM HDD and others 5400, I like the design and keyboard of HP machines.
But then again, keeping price on side for moment - which one out of these three would you suggest - considering one can buy any of them?
Thanks,
Rohit
Last edited by professorsingh; 08-09-2010 at 12:35 AM. Reason: Automerged Doublepost
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/131495-gaming-laptop-under-55k.html
gaming laptop | BoardReader This thread Refback 29-10-2010 07:33 PM
Games for laptop.. niravjadwani Gamerz 5 27-09-2010 12:56 PM
Games for laptop.. niravjadwani Gamerz 1 10-07-2010 03:33 PM
Sony Vaio Laptop shuts down v2kisad Hardware Q&A 1 28-06-2010 04:37 PM
Best 15'' Gaming Laptop within 60k!!! george101 Laptops and Netbooks 8 22-04-2010 06:38 PM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
