Old 07-09-2010, 09:54 AM   #1 (permalink)
Smile Motherboard confusion..
I have decided on all other parts of my config but i am not able to decide the motherboard. I am buying an X58 based board and want to spare around 18k for the board. I chose these 2 options.
1. ASUS X58 TUF SaberTooth
2. MSI Big Bang XPower
Both have military class components, solid state caps and all.. which of the two should i buy please help..
msaiashwin is offline   Reply With Quote
Old 07-09-2010, 06:01 PM   #2 (permalink)
Default Re: Motherboard confusion..
providing an idea about the config you decided will help us choose the right board for you.
Sam is offline   Reply With Quote
Old 08-09-2010, 01:23 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
if u are NOT into OCing abd want a good option then u can go in for Gigabyte mobo, but yes, ur usage needs to be known to us..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline   Reply With Quote
Old 08-09-2010, 05:17 PM   #4 (permalink)
Cool Re: Motherboard confusion..
Guys here's my config other than my mobo..Please suggest me a mobo from the first two options i gave in the first. Budget for mobo around 17.5k. Decent amount of OCing not very high...
Total Budget around 1.2-1.3 lacs
Processor: Intel Core i7 950 ( I heard of a price cut when is it?)
CPU Cooler: Corsair H50 or Cooler Master hyper N620?( Decent amount of OCing not very high)
RAM: Corsair Dominator 6 gb(3X2gb) 1600 Mhz
Graphics Card: GTX 460 SLi or Zotac GTX 480 AMP! edition card?
Hard Disk: 2X1TB Seagate
Power Supply: Corsair HX 850( Is it enough?)
Cabinet: Cooler Master HAF-X
UPS: APC 1kVA
Monitor: Samsung PX 2370
Keyboard: Microsoft SideWinder X4(+ some mouse)
OS: Windows 7 Home Premium
Old 08-09-2010, 07:50 PM   #5 (permalink)
pegasus's Avatar
^ Your config is very nice- i wish i could have a pc like that.
May i suggest a few things?
dump both. Get a Noctua U12P SE2 for build quality and good performance with silence, Prolimatech Megahalem/Megashadow for good performance (Noctua D14 is very big )
Please do check for RAM compatibility with the motherboard you buy. Dominators are good usually but have their own quirks at times.
If you can afford GTX460 SLi and can manage to tweak the computer on your own for any issues, you may try GTX460 SLi.
2x 1TB Seagate = 2x 3.2K (?) odd > 6K.
Get a 500GB single platter for OS and a 2TB for dump
Good Choice no doubt.
HX750 will suit your present requirements equally well i feel and save you some money without compromising over any advantages the HX850 provides.
But if you want HX850 and afford it, i cannot say no obviously.
UPS: APC 1kVA
pegasus is offline   Reply With Quote
Old 10-09-2010, 07:53 AM   #6 (permalink)
Smile Re: Motherboard confusion..
what about the mobo? If I take the msi big bang xpower should i connect the additional 8 pin cpu as well as the addition 6 pin pci-e power on the mobo?
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
