Old 06-09-2010, 10:43 PM   #1 (permalink)
Default How much will TFX0250d5w Dell SMPS cost in Mumbai
How much will TFX0250d5w Dell SMPS cost in Mumbai.Where will I be able to procure one from? Is there any other SMPS compatible with this Desktop model.
meghnakochar is offline   Reply With Quote
Old 06-09-2010, 11:23 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: How much will TFX0250d5w Dell SMPS cost in Mumbai
Is it a system OEM by DELL..? If yes, then ideally you should contact them. How old is the system. What configuration..?
asingh is offline   Reply With Quote
Any DELL Employee here who can get me a laptop at Discount ? Prashant.Narayan Laptops and Netbooks 16 31-03-2011 09:13 PM
Will this SMPS do or do I need better? FilledVoid Hardware Q&A 18 23-04-2010 12:07 AM
Buying New Laptop: ~30K Budget MetalheadGautham Laptops and Netbooks 42 28-12-2009 01:55 AM
HDD cooler and SMPS in Mumbai ajayashish Hardware Q&A 4 18-01-2007 09:06 PM
