Old 05-09-2010, 10:48 PM   #1 (permalink)
Default MicroATX vs ATX MOBo
Hi guys
I need clarification on whats the difference in microATX and ATX MOBO's in market ?
Apart from form factor what else is different ?
which one should a gamer choose ?
noob is offline   Reply With Quote
Old 05-09-2010, 11:36 PM   #2 (permalink)
Default Re: MicroATX vs ATX MOBo
The fundamental difference between a microATX board and a full ATX board is only in the form factor, i.e., physical size.
An ATX board, being larger, has more space and usually has more expansion slots. Earlier, an ATX board used to have 5 or 6 PCI slots and a uATX 3 PCI slots. These days, it's usually 2 PCI slots for the uATX and 4 for the ATX, but these are not fixed standards.
Since a uATX has fewer expansion slots, manufacturers usually include a lot of onboard features such as graphics (IGP), network interface, sound, IEEE1394 (Firewire), etc. Some do not have a graphics card slot (AGP/PCI-E). A full ATX board, having more slots, may not have some of these onboard devices. But again, there is no fixed standard as to what is included on either board.
There is no fundamental reason why you should choose one or the other for gaming. Choose one that has the features you need.
pimpom is offline   Reply With Quote
Old 06-09-2010, 12:05 AM   #3 (permalink)
yup, its only the form factor. Nothing else.
Old 06-09-2010, 01:46 AM   #4 (permalink)
also if the cabby isn't tall, ATX will touch the PSU (if bottom placed) or leave very little clearance at the bottom. so check your cabby's height if going for ATX.
Sam is offline   Reply With Quote
Old 06-09-2010, 06:56 PM   #5 (permalink)
True Evil Never Dies
Death_Knight's Avatar
Yes feature wise they are almost same. But I like ATX because of their array of expansion slots. An extra PCI card on a mATX board chokes the free air supply to the Graphx card cooler, but no such problem in ATX since you can maintain a large gap between them.
PCI cards one may need still today: extra LAN port, internal TV tuner, sound card... so on & so forth.
Frostmourne: i5 760|MSI P55-GD65|2X4GB 1600 Vengeance|GTX460 HAWK|2.5 TB|CM 690II+|TX750
BenQ G2220HD|Creative T6100|MS SidewinderX4|Razer DA|SS QCK MASS|Xfones PC2400|Epson TX121
Lappy: HP dv9507tx
Death_Knight is offline   Reply With Quote
Old 06-09-2010, 10:34 PM   #6 (permalink)
but dont you all think that it might have issues with air-flow and GPU placement ?
Old 06-09-2010, 11:35 PM   #7 (permalink)
^why do you think that way? maybe for multi GPU setup, the slots could be closer, else no difference...
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5532 Yesterday 10:13 PM
Help Upgrade On My P5B Mobo Pravas Hardware Q&A 5 13-09-2010 04:07 PM
Need advice on Mobo selection ojha_riddhish Hardware Q&A 8 01-04-2010 08:52 AM
