Old 05-09-2010, 05:04 PM   #1 (permalink)
clerkman1612's Avatar
Default AM3 motherboard for 6k
I have made a list of all components of New Assembled Desktop PC.
Plz tell me which motherboard will be most suitable for me.
I prefer a motherboard without integrated graphics.
As I have read in ur forum that Asus motherboards are crap so I m not prefering it.
AMD Phenom II * 4 955 3.2 GHZ
3 * 2 GB DDR3 Kingston RAM 1333 Mhz
Benq 22" G2220 Full HD Monitor
Cooler Master Gladiator 600
Tagan StoneRock Series TG 600 (PSU)
Microtek 600 VA UPS
2 * 500 GB Western Digital Caviar Blue Hard Disk
Palit/Zotac Nvidia Geforce GTS 250 1 GB Graphics Card
Motherboard ?
MSI 880 GMA E45
Gigabyte GA- 880 GMA - UD2H
So plz tell me which mobo I should choose? If you suggest any other mobo then plz tell me. My budget for Mobo will be max 6000 Rs
I will use this PC for mid-gaming purpose.
clerkman1612 is offline   Reply With Quote
Old 05-09-2010, 07:21 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: AM3 motherboard for 6k
your config is not optimized. can you give your total budget so that we can suggest you a good config.
Old 05-09-2010, 07:25 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
i was going to say the same thing but you posted before me
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 05-09-2010, 07:27 PM   #4 (permalink)
Question Re: AM3 motherboard for 6k
My maximum budget is Rs 50000. After that amount I cannot afford.
And I like AMD platform for mid-gaming purpose.
Plz now suggest.
Old 05-09-2010, 07:35 PM   #5 (permalink)
Phenom II X4 955 3.2GHz B.E. @ 7.8k
Gigabyte GA-880GM-UD2H @ 4.5k
2 * 2GB DDR3 1333MHz @ 5k
Zotac GTX 460 @ 13.5k
Seagate 1TB @ 3.5k
LG H55N DVD @ 1k
Corsair VX550W @ 4.7k
CM elite 430 @ 2.6k
BenQ 22" G2220 Monitor @ 7.5k
Total - 50.1k
Old 05-09-2010, 07:44 PM   #6 (permalink)
The Assassin
Cybertonic's Avatar
Just what both of us had suggested on another thread today
Steam : $/@$]-[ DK
Old 05-09-2010, 09:29 PM   #7 (permalink)
Cool Buddy's Avatar
the corsair power supply is better than tagan stonerock. so go for vx550
MSI board you mentioned is also a good board in case Gigabyte one is not available.
Don't get confused between Gigabyte GA-880GM-UD2H & Gigabyte GA-880GMA-UD2H
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 05-09-2010, 09:45 PM   #8 (permalink)
Cool Re: AM3 motherboard for 6k
I need to confirm 2 things.
1) Zotac GTX 460 is a very powerful Graphics Card. So it will consume a lot of electricity from PSU. So Corsair VX 550W will work good in it?( I have already read PSU Guide in the forums' of this site.)So if Corsair VX550W is not sufficent for that Graphics Card then will it blow up anytime?
2) I m even now also confused between Motherboard GigaByte GA-880GM-UD2H and GigaByte GA-880GMA-UD2H. Are both same or different model of the GigaByte Motherboards?
Plz tell me!
Old 05-09-2010, 10:02 PM   #9 (permalink)
True Evil Never Dies
Death_Knight's Avatar
1. VX550 can give max output of 650v. So, no need to worry
2.880GMA => AMD SB850 = SATA 6Gbps + USB3 support
880GM => AMD SB710 = SATA 3Gbps + USB2 support only
Check the Gigabyte site for detailed specs
Frostmourne: i5 760|MSI P55-GD65|2X4GB 1600 Vengeance|GTX460 HAWK|2.5 TB|CM 690II+|TX750
BenQ G2220HD|Creative T6100|MS SidewinderX4|Razer DA|SS QCK MASS|Xfones PC2400|Epson TX121
Lappy: HP dv9507tx
Death_Knight is offline   Reply With Quote
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
Which is best motherboard for AMD athlon 2 X4 630/phenom X2 550(socket AM3 type) amit.n Hardware Q&A 4 27-04-2010 10:21 AM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
