Old 04-09-2010, 03:35 PM   #1 (permalink)
Post New System: Virtualization
Hello All,
I am planing to build a new cpu. My primary requirement is that I have to run many server OS together.I am not a gamer and I will not be buying a graphic card, however I might buy one in a few months time so would like to have that capability on the motherboard.There should be a support for H/W virtualization..I can spend 10k extra if it gives me a substantial inc in the performance.Please suggest me a suitable configuration.Thanks !
1. What is the purpose of the computer?
A: I need to run server Windows server 2003 and 2008 with client machines.
2. Are you open to alternate ideas/products giving similar better performance
but offering more VFM/ sellers? If not- why?
A: Yes
3. What is your MAX budget?
A: 40k
4. Planning to overclock?
A:Yes,in future
A: Base OS would be windows server 2008 then there will be many virtual machines.
A: 2 TB
7. What resolution will the screen run at & whats the size of the screen you
want?
A: For now I have my old 15" samsung monitor,but, will change it to a good 22" in the future.
A: 5
A: It will be an assembler.
A: Within a month
A: Yes
A:Graphic Card,Monitor,Keyboard,Mouse.
A: New-Delhi,no.
A: At least 8 GB of ram [might inc in future].
rawgeek is offline   Reply With Quote
Old 04-09-2010, 04:21 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: New System: Virtualization
At a budget of 40k, you have to go for AMD. For now I'm not suggesting any GPU or monitor.
Here goes my suggestion:
AMD Phenom II X6 1055T 3.2 GHz @9.7k
MSI 880GMA-E45 @ 6k
Corsair TR3X2G -1333 XMS3 C9 6 GB Kit @ 7k
Seagate Baracuda 7200 rpm 2 TB with 32MB Cache @ 5.5k (Price is in deltapage.com)
Corsair VX550W @ 4.7k
Cooler Master Elite 430 @ 2.6k
LG 22X SATA DVD Writer @ 1k
Microsoft Comfort Curve 2000 @ 1k
total is around 37.5k. Spend the extra money to buy some 120 mm Cooling Fans from Cooler Master.
This system will be well balanced for all the applications you mentioned. The Onborad HD 4250 with 128 MB dedicate DDR3 ram is powerful enough to handle your 15" monitor. Even some gaming is also possible. For PSU , I have suggested the 550W, although the VX450W is enough for it. It is because you said thet you are going to add Graphics card in future. But still, you can go with VX450, as it can also handle medium Graphics cards without any difficulty.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 04-09-2010, 04:40 PM   #3 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
that was exactly what i was going to suggest 1055t + msi 880gma-e45
go for this setup
it suits your needs completely
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now   Reply With Quote
Old 04-09-2010, 08:19 PM   #4 (permalink)
increase ram to 8Gb & cabby to NZXT Gamma & add 4-5 fans (needed). also for PSU, VX450W will be sufficient. this will keep the PC as well as OP happy (& cool).
Sam is offline   Reply With Quote
Old 04-09-2010, 10:47 PM   #5 (permalink)
Point Blanc
check motherboards support for HW virtualization.
If not wrong you are thinking to run Hyper-V, it needs HW virtualization support.
Otherwise if you are running VMware Workstation or Virtual PC they will work fine.
In VMware's performance is with HW virtualization enabled.
acewin is offline   Reply With Quote
Old 05-09-2010, 03:32 PM   #6 (permalink)
Thanks Guys for your prompt responce
Please tell me the difference between x6 1050 and x6 1090,how much more will I have to spend and what will be the inc in performance?And yes I am planning to use Hyper V,do we have support for that in MSI 880GMA-E4?We can drop Microsoft Comfort Curve as I already have keyboard and mouse.I do plan to buy a 22" monitor in 2-3 months,would Onborad HD 4250 with 128 MB dedicate DDR3 ram be enough for that?
Once again thank you for taking out time to reply and assisting me.
Old 06-09-2010, 10:43 AM   #7 (permalink)
laborare est orare
Cilus's Avatar
1090T is the higher end big brother of 1055T.
The main difference is 1090T is a Black edition or BE processor, having an unlocked multiplier. So you can over clock the processor by just increasing the multiplier. This is mainly for gaming. So it is having more over clock potential.
2nd difference is default clock speed. 1090T is clocked 400 MHz higher tan 1055T.
The price difference is almost 4.5k and the kind of operation you have mentioned, i don't think it is justified to spend the extra money. 1090T's main target audience is Gamers
Old 06-09-2010, 03:37 PM   #8 (permalink)
as u've planned to over clock in future , 1090t will cost u a premium.
if u're willing to spend then 1090t's definitely a good buy
Old 07-09-2010, 07:25 PM   #9 (permalink)
I am going with 1055T and will use the extra money to get more ram,around 10 GB.
Thanks for the support guys........u all rock
Old 07-09-2010, 07:35 PM   #10 (permalink)
^^ get 8Gb. will be in dual ch. will help boost performance.
Old 20-10-2010, 12:07 PM   #11 (permalink)
Thanks 2 all of u.....I got my New pc....x6 1055.....Corsair 8GB 1333Mhz......MSI 880GMA-E41....Cooler Master 550W.
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
Sony PlayStation 3 (60GB) kinshuk99 Gamerz 6 16-06-2007 12:02 PM
Very Strange Problem!!! shivaranjan.b QnA (read only) 1 15-06-2005 09:00 PM
