Old 04-09-2010, 11:50 AM   #1 (permalink)
rik
Unhappy help me to Upgrade my Desktop
Hello Everybody,
My pc confg is-
CPU Pentium4 3.06GHZ
Motherboard D-101 GGC
512 mb DDR
HDD 80 GB SATA.
Now i want to upgrade my pc with 1gb ram & 160 gb external harddisk.so my question is in kolkata can i exchange my 512mb ddr ram with 2gb ddr ram(My pc Supports 2 GB Ram or not Plz Let Me Know) & If then Where? & what is the price of 1gb DDR ram (which company is the BEST?) & 160 GB Ext HDD (BEST Company).Plz Help Me as my pc is creating prob nowadays.
Thanking U
rik is offline   Reply With Quote
Old 04-09-2010, 02:14 PM   #2 (permalink)
Default Re: help me to Upgrade my Desktop
Originally Posted by rik View Post
Hello Everybody,
My pc confg is-
512 mb DDR
HDD 80 GB SATA.
Thanking U
It seems your motherboard supports only up to 1GB RAM per slot.
Intel® Desktop Board D101GGC — System memory
The price of DDR800 is about 2k for 1GB, although this will vary somewhat depending on where you buy it.
pimpom is offline   Reply With Quote
Old 04-09-2010, 03:38 PM   #3 (permalink)
you need to change your motherboard for fitting in your RAM requirments
With Regards
Jatin Jha
www.twitter.com/jatinjha
way2jatin is offline   Reply With Quote
Old 07-09-2010, 12:16 PM   #4 (permalink)
rik
Thanks for ur replies & Sorry to say that I don't understand the meaning of "1GB Ram per Slot".What is DDR800? Can u explain me?
With Regards
rik
Old 07-09-2010, 04:12 PM   #5 (permalink)
bobby23's Avatar
you mean DDR2 800mhz??? I don't think DDR has 800mhz RAM. It's the frequency of your RAM. 1GB Ram per Slot i am not sure but i think in each slot the max capacity you put is 1GB
bobby23 is offline   Reply With Quote
Old 10-09-2010, 04:01 PM   #6 (permalink)
Burning Desire
edvin_158709's Avatar
follow this link Intel® Desktop Board D101GGC — Technical product specification and have a look at this one D101GGC Technical Product Specification [PDF] your board support DDR1 (type of RAM module) 400mhz and 333mhz its better to change motherboard itself to get change from high cost low bandwidth module look for Gigabyte G41 Combo though it is Micro-ATx but it support both DDR2 and DDR3 so for an entry-level board it's quite a good thing.
here the specs GA-G41M-Combo (rev. 1.3) - GIGABYTE
Change is a thing that is very difficult to adopt but its the only thing that brought Revolution
edvin_158709 is offline   Reply With Quote
Old 10-09-2010, 07:46 PM   #7 (permalink)
Cool Buddy's Avatar
Yeah better change the mobo if possible. DDR RAM is expensive, more than DDR3, better get a mobo & DDR3 RAM. Although that would cost more than just DDR RAM, still it would be worth it.
Nokia 5230 :(
Canon IXUS 115 HS :)
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5532 Yesterday 10:13 PM
Please give Suggestion about my upgrade!!!!!!!!!!! Tenida Hardware Q&A 16 27-08-2010 12:48 PM
8800 GT shot to hell, need to upgrade card + system... suggestions please? :) kiranb28 Hardware Q&A 34 26-08-2010 01:52 PM
Advice requested for assembling cheapest Gaming Desktop prakum Hardware Q&A 19 16-06-2010 08:08 AM
Please suggest a Desktop Upgrade manistar Hardware Q&A 6 02-10-2009 12:59 AM
