Old 02-09-2010, 05:00 PM   #1 (permalink)
Default Need a Socket 754 Motherboard
Friends, my younger sister's Socket 754 motherboard [MSI K8MM3-V] is dead.
i went to all the possible local "big" & a few "small" vendors to inquire if there is a new motherboard for sale, but no luck.
i looked up on the web & i found this -
Socket 754 Motherboards | motherboards socket 754 | Socket 754 Motherboard
Based on the above link, my first choice is the Gigabyte motherboard [GA-K8U] but if it is not possible to get that due to non-availability or out-of-stock then i do not mind getting any other brand as long as i get the stipulated warranty.
i reckon the warranty period given by all the major motherboard brands is 3 years, right?
i asked my sister if she was contemplating a new motherboard+processor+memory upgrade but she seems to be happy with her current configuration. About 8 months back, she put a new 1GB DDR RAM module & does not want that to go waste.
i am quite reluctant on an online purchase, so if there is or are a few places in Mumbai where i can get this then do let me know. i am going to Mumbai soon.
As always, i await your feedback
let us all see the "i" in the "u".
insaneYLN is offline   Reply With Quote
Old 04-09-2010, 02:26 AM   #2 (permalink)
Default Re: Need a Socket 754 Motherboard
Friends, i apologise for my stupidity.
i should have checked on Gigabyte's website first but realised it later.
Having looked at
Socket 754 - GIGABYTE
i feel i should go with NVIDIA as the vendor & 6100 as the chipset. So which one should i opt for?
GA-K8N51GMF (rev. 1.0) - GIGABYTE
OR
GA-K8N51GMF-RH (rev. 1.0) - GIGABYTE
Friends, if you know any places or dealers in Mumbai who still have such motherboards in stock, then kindly please inform me.
Ingram Micro & Neoteric are the only 2 dealers listed on Gigabyte's Where To Buy link
Motherboard - GIGABYTE
Friends, do respond..
Old 13-09-2010, 04:31 PM   #3 (permalink)
Friends kindly help & please reply.
Old 13-09-2010, 05:17 PM   #4 (permalink)
^^ i'll simply suggest you consider an upgrade cause these boards are extremely old & hence very hard to come by. so better save your time & money. opt for an upgrade. you may end up spending around 1500-2000 more but it'll be worth it. as least you (or your sister in same sense) will get better performance. AMD sempron + Gigabyte 740G + 1Gb DDR3 will total cost you 5k & will easily outperform the existing setup by a good margin. even if you end up with that board (the one you searching) & end up paying ~3k. what is the benefit?
Sam is offline   Reply With Quote
Old 21-09-2010, 12:37 AM   #5 (permalink)
@ Sam.Shab
Thank you for your valuable advice Sir. i have tried to put your point across my sister but somehow she is reluctant to upgrade & adamant on sticking by her "dated" configuration.
My sister..
i will give her some more time to change her mind but till then if any of you are able to locate a dealer (preferably in Mumbai) who still has my selected/desired choice of the Socket 754 motherboard then kindly keep me updated.
Thank you
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
