30-08-2010, 03:19 PM
Swimming, eh??
18k built
Need a rig.
Cpu+mobo+ram+hd.
Max budget 18k.
Main purpose gaming.
I know a athlon x4 will be sufficient.
But i want an intel built option aswell.
30-08-2010, 07:05 PM
Re: 18k built
which psu, cabinet, monitor you are having?
also do you have a graphics card??
30-08-2010, 09:51 PM
Swimming, eh??
Re: 18k built
Corsair vx450
nzxt gamma
msi 5770
benq g2220
all this will be bought after the initial 18k purchase.
Just asking sir, what has monitor & cabby to do with this??
30-08-2010, 10:22 PM
What The.... !!!
Re: 18k built
ok here goes
Athlon II X4 635@5k
Gigabyte 785GMT US2H@4.7k
Seagate 1 TB@3.3k
Corsair XMS3 1333MHz@5.2k
31-08-2010, 10:49 AM
Swimming, eh??
Re: 18k built
Originally Posted by funkysourav
ok here goes
Athlon II X4 635@5k
Seagate 1 TB@3.3k
dont seagate (or any brand,as for that matter) 1 GB have high failure rate?
Corsair / Gskill, is not available at the place I live.
So I will settle with Kingston.
What do you say, an intel i3 will do against Athlon II X4 635. Can an i5 be bought under my budget?
31-08-2010, 12:31 PM
Re: 18k built
Asked to suggest you better. Moreover since u game we need to take care of monitor graphic card combo.
Anyways get -
Athlon II x4 635 @ 5k
Gigabyte GA-880GM-UD2H @ 4.5k
2*2GB DDR3 1333MHz @ 5k
WD 500GB blue @ 2k
spend the extra 1.5k on ZOTAC GTX460 768MB @ 12k
31-08-2010, 03:55 PM
Swimming, eh??
Re: 18k built
I dont want to judgementive, but you guys sure love AMD...a lot.
Same here. I am biased towards AMD, rather than Intel.
But Intel does have couple of suprises under their their sleeves.
I also wanted to ask what are overclocking capabilities of Intel i3, as compared with 635?
31-08-2010, 06:12 PM
Re: 18k built
i3 ---> 4.5Ghz (with good cooler), ~3.6Ghz with stock.
X4 ---> 4.1Ghz (with good cooler), 3.5Ghz with stock.
i3 ---> the LGA1156 based one will be discontinued with no support after this year.
X4 ---> AM3 will continue support next gen proccy (as heard everywhere).
31-08-2010, 06:39 PM
Re: 18k built
nobody here is biased. we just suggest whats good..
31-08-2010, 08:33 PM
Swimming, eh??
Re: 18k built
Of course.
I dont accuse you guys of anything.
Ok then. Its set. Athlon X4 635.
Thank you.
31-08-2010, 09:43 PM
Point Blanc
Re: 18k built
@toad, you sound like normal only, people think of buying intel first than AMD  , I will do the same and buy intel rig. But when it comes to low cost and goodies involved with AMD intel gets left far behind, as I want think about future addons possible, I love what amd mobos + proccy combo has to offer than same priced intel combo.
31-08-2010, 11:49 PM
Swimming, eh??
Re: 18k built
Yea,intel comes out with different socket with every other new cpu.
I mean that just sucks.
What yeast infection will they get if they stick with one series of socket just like AMD.
Moreover,Intel has heavy influence on 1st time buyers & newbees to computer tech. hence they mess up thing, like i did.
Well I was planning to get an aftermarket HSF, and hence was deciding with overclocking capabilities in mind.
01-09-2010, 01:29 PM
Point Blanc
Re: 18k built
first time buyers mess up because of sellers  , local dealers will say this is good for what is with them and bad to what is not with them. And intel is the best because it gets them more money LOL hehe
Try good cabby more room for HSF, NZXT gamma is nice choice.
