Old 27-08-2010, 08:35 AM   #1 (permalink)
Hmmmmm
Tenida's Avatar
Question Please give Suggestion about my upgrade!!!!!!!!!!!
I have
1)Intel core 2 duo E7300@2.66GHZ
2)Msi P45 Neo 3 Fr motherboard
3)Zion 2.5 gb(DDR2@667Mhz)
4)Coolermaster Etreme power 500 W psu
5)Xfx 8600 gt
Now i want to upgrade Graphics card,power supply,Cabinet and 2gb of ram.
I have shortlisted this:-
Graphics card-Sapphire Ati HD 5770 1GB ddr5
Psu-Corsair VX 550(choosing for future upgrade)
cabinet-CM elite 430
Ram-Corsair 2gb@DDR2 800mhz(will it works with 667Mhz ram?)
Fan-1 led cm 120mm and 3 normal cm 120mm.
Please tell me this upgrade is good or not?
Tenida is offline   Reply With Quote
Old 27-08-2010, 09:39 AM   #2 (permalink)
What The.... !!!
funkysourav's Avatar
Default Re: Please give Suggestion about my upgrade!!!!!!!!!!!
very balanced and well thought upgrade plan!
you are good to go!!
yes the Corsair 2gb ddr2 800MHz ram would work with 667MHz RAMS(but Zion!! really?why?) already present,
but the frequency will get downclocked to 667 MHz
don't worry you wont notice any difference while gaming
the choice of PSU and cabinet is stellar
but if you have got 3k extra why not go for MSI GTX 460 1gb cyclone?
you can give that a thought!!
funkysourav is offline   Reply With Quote
Old 27-08-2010, 09:50 AM   #3 (permalink)
Hmmmmm
Tenida's Avatar
Talking Re: Please give Suggestion about my upgrade!!!!!!!!!!!
Thanks.
Zion is good value ram i think.Till now it performs good(correct me if i am wrong)
Whats is the actual price of MSI GTX 460 1gb cyclone?Will it be avail in kolkata?
Old 27-08-2010, 10:04 AM   #4 (permalink)
better go for 4Gb 800Mhz ram. also your processor can be OC to 3Ghz on stock cooler with minimum effort. try to do it.
GTX460 will require extra cooling. need add more fans. if you really not in hurry, why not wait for GTS450?
Sam is offline   Reply With Quote
Old 27-08-2010, 10:16 AM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^GTS 450 is a nice idea
who knows it may outperform 5770 and still available @9k or something
its gonna be a really good deal
we just have to pray to god that it shouldn't have any heating issues
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 27-08-2010, 10:25 AM   #6 (permalink)
Hmmmmm
Tenida's Avatar
Will 4Gb 800 mhz ram will boost extra performance?I am thinking 1gbx2 800 mhz and 1gbx2 667mhz(already have).I have a 4 ram slot.
I don't know how to oc!!!
My 8600 gt went kaput so i have no display.My motherboard has no IGP.
So i need graphics card urgently.
please tell me the price of MSI GTX 460 1gb cyclone?
Old 27-08-2010, 10:31 AM   #7 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^right now the price of gtx 460 varies from 12k to 13.5k (from places to places and availability)
--Get Backers
Old 27-08-2010, 11:01 AM   #8 (permalink)
Hmmmmm
Tenida's Avatar
What is performance diff.between HD 5770 vs gtx 460?
Old 27-08-2010, 11:05 AM   #9 (permalink)
Wise Old Ghoul
Piyush's Avatar
460 outperforms 5770 but not that nicely
u can refer to the benchmarks
http://www.tomshardware.com/reviews/...mi,2684-8.html
--Get Backers
Old 27-08-2010, 11:15 AM   #10 (permalink)
Hmmmmm
Tenida's Avatar
So what should i do 5770 or gtx 460?
5770 is cheaper than 460.
Old 27-08-2010, 11:16 AM   #11 (permalink)
Cool Buddy's Avatar
pairing 667 & 800 RAM may be risky as in the system may become unstable. buy the RAM. if the system becomes unstable, sell the old RAM & buy new matched ones.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 27-08-2010, 11:21 AM   #12 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^is any sort of tweaking is possible to avoid any possibilities of risks?
--Get Backers
Old 27-08-2010, 11:29 AM   #13 (permalink)
Hmmmmm
Tenida's Avatar
Thanks CoolBuddy.
---------- Post added at 11:29 AM ---------- Previous post was at 11:22 AM ----------
Guys please tell me what card should i go for Sapphire HD 5770 1 GB ddr5 or Msi GTX 460 1 gb ddr5?
Old 27-08-2010, 11:33 AM   #14 (permalink)
Wise Old Ghoul
Piyush's Avatar
if budget permits then go for 460
else go for 5770 ,it wont dissapoint u either
but i'll suggest u to go for 5770 and spend the rest of the money on rams and other upgrades
--Get Backers
Old 27-08-2010, 11:42 AM   #15 (permalink)
Swimming, eh??
toad_frog09's Avatar
Sure enough the 460 performs better than 5770, but spendin 3k for increase in few notches fps is not worth it.
If you really want a killer gcard,then go for something that is in the range of 15-16 k.
Or else the 5770 is enough.
& would you be settling for sapphire,cuz msi hawk 5770 looks like an excellent product.
toad_frog09 is offline   Reply With Quote
Old 27-08-2010, 11:47 AM   #16 (permalink)
Hmmmmm
Tenida's Avatar
Thanks i will go for Sapphite Hd 5770.
---------- Post added at 11:47 AM ---------- Previous post was at 11:42 AM ----------
MSi hawk is not available in Kolkata.
Old 27-08-2010, 12:48 PM   #17 (permalink)
Cool Buddy's Avatar
5770 is a good card for 9k. no mistakes in selecting that one
about the RAM, it's not necessary that the system will become unstable. So the op should buy the 800 Mhz RAM coz 667 Mhz won't be available anyways. But I'd say if 667 Mhz is available, buy that only. That way there is more certainty. half the performance boost that could have come from the increase in frequency is offset by the slower timings anyways. Also, even if there is no problem after pairing them, the 800 Mhz will run at 667 Mhz only. So enquire for 667 Mhz. If not available then only buy 800 Mhz.
And after that if there are problems, sell the older ones (667 ones) and buy a fresh pair (800 Mhz).
Nokia 5230 :(
Processor upgrade in Laptops!!!help shijinmrx Hardware Q&A 3 15-07-2010 02:14 AM
suggestion in buying a new system for around 20k prasanthsd Hardware Q&A 5 10-07-2010 08:02 PM
i need a suggestion on taking up java as professional sakarsh666 Education 0 26-06-2010 09:42 AM
TV Tuner for LCD - Suggestion Plz GhostRecon Hardware Q&A 1 18-03-2010 04:22 PM
Upgrade Suggestion nishant_nms Hardware Q&A 14 07-08-2006 01:21 PM
