Old 26-08-2010, 08:43 PM   #1 (permalink)
Smile which LapTop....???
I am looking for a laptop for extreme use. Typically zbrush , Modo , Autodesk 3DS Max 2011 and Autodesk Maya 2011 & Autodesk Softimage 2011. Would prefer a 64 bit system and also would use it for multimedia applications like storing, conerting and playing my video and audio files. Can you suggest a really high performance and heavy duty laptop suitable for the above? My budget is 50 to 60
AMD Phenom II X2 555 ( 3.2 GHz ) + ASUS ATI Radeon HD 4350 1GB DDR2 + ASUS M4N68T-M V2 + DDR3 - 1333 4GB RAM + seagate 500 GB sata
savithk is offline   Reply With Quote
Old 27-08-2010, 01:37 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: which LapTop....???
for the above requirements as well as the price budget, u wud need a lappy with Good processor, min. 4GB DDR3 RAM, 1GB HDD (but almost all lappys come with 500GB SATA HDD) and a really good GPU to compliment the RAM and processor.
at this moment, Acer 5470g, 5475g and also Dell Studio XPS (but it has 512MB gpu and 320GB HDD with 6GB RAM)
as seen here ----> Dell Laptops/ Notebooks - Home & Home Office | Dell India
wud fit ur budget....Acer doest not hv the best of build quality (far inferior to Dell, HP, Sony) but thats all i can think of at that price
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline   Reply With Quote
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5532 Yesterday 10:13 PM
acer laptop and big trouble , urgent help needed fun2sh Laptops and Netbooks 6 19-04-2010 08:10 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
