Originally Posted by adityamgk
@dsmarthy will i be able to connect both in lan that is can i share files and all between the 2 pc's with the above equipment?
u can right click on any folder and then select Properties > SHaring, then specify a name for that particular folder (wich needs to be shared) and then u are done..
an easier way is to install Cisco's Network Magic Pro (u can get them from ...ahem.... sources.. and then do it in a much more GUI based way..
(its helpful wen u hv 2 diff, OSes running say, one is 32bit XP and the other is 64bit Vista or WIN7 )
Cheers n e-peace.....
