25-08-2010, 08:12 PM
Need help to check which option would be better for power consumption
I have a laptop and a desktop. I wanted to know which is the better option when I'm downloading something off the net in terms of power save.
1. Keeping laptop on
2. Switching of the monitor of desktop and leaving the CPU on.
Which among the above would be better in terms of power saving.
I assume for laptop I will have around 2hrs of backup time after which it may shut down. so Maybe I have to keep it charging
Kindly give your suggestions.
Reason: typo
25-08-2010, 10:04 PM
Re: Need help to check which option would be better for power consumption
The difference depends on the configuration of each. The power used by a powerful high-end laptop may not be much less than that of a low-power desktop without the monitor. But in general terms, a laptop will use less power.
For non-demanding use like downloading, a laptop will generally use much less than 100W whereas a desktop may use something like 150W. These are only rough guides as the actual consumption depends on the configuration.
If you use a laptop to download for extended periods, it's best to use AC power through the adaptor/charger. This way, it will not drain the battery and also keep the battery fully charged. Automatic charging controls in the laptop will prevent overcharging.
26-08-2010, 05:54 AM
yeah, keep the laptop on AC power. It will consume much less than a desktop. But it would be nice if you could give the configuration of both the machines for a better opinion.
26-08-2010, 02:46 PM
Here is a catch I observed that the power adapter is getting heated up when I leave it on for charging for a long time. Hence I'm little apprehensive of leaving the Laptop on with it connected to A/C source for anything more than 2-3 hours.
In case I'm downloading something which will take an average time of 4-6hrs which option would be better.
With regards to configuration what all details do you need me to post in here which can help us better.
26-08-2010, 03:50 PM
Anything that uses power gets hot because there's always some loss and the loss is converted into heat. But heating is not necessarily the same as overheating.
Laptops and desktops and their power supplies are designed for continuous use without overheating, but anything in heavy use can break down after some time. There's no black-and-white answer and we have to balance our needs with the risks.
You could gain some additional safety margin by blowing on the laptop and its adaptor with a small table fan. Or, (and this is something I've thought of just now) you could place the laptop AC adaptor on top of an up-ended flat-bottomed aluminium pot!  The aluminium will conduct part of the heat away and dissipate it more easily than the adaptor alone.
This is like comparing apples and oranges, as the saying goes. A desktop may be more suitable for continuous use, but your primary concern is power saving, in which case the laptop wins.
All the usual things, really. Processor, RAM, HDD, graphics, etc. This will help evaluate the power consumption.
One possibility that may be considered by those addicted to downloading large files all the time is to have a dedicated downloading machine. Downloading files is a non-demanding task. A d/l machine could be built up of old discarded but working parts. A low power CPU like an old Celeron or Sempron, 128MB RAM, etc could be used. The low power used by such a configuration could be reduced further by underclocking.
For example, I still have a 500 MHz Pentium III CPU and a working motherboard with 128MB SDRAM. If I were a heavy downloader, I could use that purely as a downloading machine and it would be just as good as a modern machine for that purpose.
26-08-2010, 04:40 PM
Thanks for your insights on this one.
26-08-2010, 05:59 PM
It would be more effective if you get a faster internet connection
26-08-2010, 06:15 PM
I'm happy with 256 Kbps. Also I don't download that often.
26-08-2010, 06:33 PM
get yourself a desktop with a good efficient PSU. this will surely loose the power consumption test to any laptop in market but you can run it 24X7 & will still be smiling. run a laptop like this, & prepare for RMA
also a Sepmron/Dual Core + a cheap motherboard + 1Gb ram + 250-500Gb HDD & other parts will cost much less than a laptop or a netbook & in the long run, will be better choice. also add up money wasted in electricity to it, price of a desktop will still be lower.
27-08-2010, 12:48 PM
Core i7 (nehalem) Owner
totally agree with Pimpom (on the Dedicated PC for d/loading stuff) and also with Sam..
i myself was using my p4 350Mhz PC jus for dedicated d/loading stuff, but tat gave way and then i purchased an Atom based PC with no GPU (ofcourse, atom based mobo do not hv a gpu slot) and now using it 24x7 (nfact, saying i use it 15days at a stretch b4 turning it OFF for a mere 8 hrs for the PC to rest) wud be more appropriate..
to the OP: many ppl use even NETBOOKS for d./loading stuff, but yes if u jus wanna choose b/w PC and a lappy, then for power saving needs, Lappy wins.. (cant say abt the durability of the lappy) though..
Cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
27-08-2010, 04:21 PM
Too be really honest I use very less of laptop. I prefer the desktop, really tough using the laptop without mouse still getting use to it.
I would say I want to look something which can both save power as well as won't effect the PC much.
Thanks a lot for your suggestions. Appreciate it!
28-08-2010, 11:39 AM
hmmm... i agree to that, as i had a lil' tough time (wen i myself got a lappy at first) so it was a handicap state for me as i was used to the Mouse on my PC...
hmmm... so u hv the PC as well as the Lappy and then u deciding wich one to use for d/loading stuff..??? or u still in rough plans to buy either one of them..???
if thats the case, then u can buy an Atom based PC or even a lower config PC as ur budget permits..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
28-08-2010, 12:24 PM
he said he does not download much, so why we talking about download rigs?
28-08-2010, 12:59 PM
ohh, sorry missd tat part...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
28-08-2010, 02:45 PM
He mentioned that only later in the thread.
His initial question was about saving power while downloading for extended periods. I and others pointed out that a laptop uses less power, but he's also concerned about stressing the laptop. Hence the sub-topic of a dedicated download rig.
The OP mentioned a download time of "an average of 4-6 hrs". If this were a one-time download, it would hardly matter whether he uses a laptop or a high-power desktop. The difference in his power bill would be just a couple of rupees at most. So the suggestions were made with regular downloading in mind.
In any case, forum discussions are not just for the benefit of the OP only. They are intended to be a useful reference for all readers. If you'll reread my earlier post, you'll see that my suggestion of download rigs was addressed to all heavy downloaders.
29-08-2010, 12:58 PM
hey pimpom, can an ATOM based NETBOOK (say, an Acer make or Asus EEEPc) be used for 24x7 d/loads..??? or say, if its getting hot for the NETBOOk, i can get a cooling pad...to hv its backside vents cooled
coz its really space saving (for me) as currently i hv a Atom based Desktop setup and i really wanna clear out the clutter (coz my 2nd is a core i7 rig, as in my siggy)...so plz ur inputs needed..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
29-08-2010, 03:39 PM
netbooks usually don't get that warm. you can give netbook around 4-5hrs rest daily. this way temp will be under check. say 5hrs download & 1hr rest. also if netbook got option to turn the screen off, all the heat generated will be by the HDD & proccy-mobo combo. this should never reach high alarming rates if you unplug the netbook & turn it off for 1hr every now & then (the charger/adapter too will be cooled down in meantime). or let the netbook charge in meantime, if you use battery power during download.
30-08-2010, 11:20 AM
I retrofitted a steel mesh tray under my desk that houses my netbook, which doesn't get hot at all because it's well ventilated on all sides. I turned off the wireless adapter and hooked it physically to the router to save power and heat dissipated by the wireless device. Tinkered with power management, so closing the lid causes it to kill the display instead of going to sleep mode. Hooked it up to my desktop monitor through the spare D-sub port, so switching between the Desktop and Netbook is a one touch affair. I also hooked up the keyboard and mouse to a USB hub, so I can route them to the netbook and desktop with a simple swap. Finally, I installed a Broadcom Crystal HD decoder card (Rs 1100 shipped ebay, Hong Kong), which runs high bit-rate 1080p mt2s video files smooth with just 10% CPU utilisation. This way, I use my netbook for downloading, surfing and also to watch full-HD movies (entertainment), thereby leaving the PC free for the sole purpose of gaming.
Samsung P2370MS | Phenom II 555BE | MSI 790GX | 4GB Corsair XMS3 DDR3 1600 | CM Hyper 212+ | Sapphire HD 4850 (1GB) | Corsair CX400 | NZXT Gamma + Sentry2 fan controller | Razer Abyssus + Rantopad H3
30-08-2010, 12:23 PM
#19 (permalink)
ok, thanx a lot SAm for this good explaination.. now plz kindly tell me wich is the cheaper netbook for the same purpose (downloading)..
say in the range of 12-15K wich has wifi+bluetooth... and a good build too, NOT like those plasticky feel to it..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
30-08-2010, 07:32 PM
#20 (permalink)
welcome buddy. well if build quality matters, Asus or Samsung. i can't say anything about MSI. i have not read any fresh reviews about it. Acer's build isn't hidden from anyone. their build quality isn't at all good. Toshiba & others are hard to come by.
Samung will cost appx 15k. but i feel it got no bluetooth. maybe wifi present. Asus first series of SeaShell netbooks should cost below 15k. but again lacks many features. all i can say, search all online shops.
31-08-2010, 04:51 PM
#21 (permalink)
Nice discussion.
Just adding a few thoughts i had posted elsewhere.
If you want something just for downloading and are better of using just one main computer, i have seen some guys with powerful gaming rigs use netbooks for downloading instead of assembling rigs with Atom integrated motherboards.
eg. Samsung N128 (was 13.5K)
Some upgrade the internal HDD if they are unable to transfer downloaded data regularly.
Some transfer daily/regularly and some use external HDDs with existing config.
Pros-
- Very low on power consumption-
- efficient
- Very low on heat and noise
- compact and space-saving
- Battery backup
- Free LCD screen+KB+mouse
Cons-
- 1 year warranty
- not upgradeable
But if you want a download rig + media server, i guess the only option will be to get a full-on desktop computer.
But that may double up as your HTPC too.
Pc to for for 24X7
That said, if your laptop is not too heavy on the specs, especially if it has no discrete graphics, you may easily use the same for downloading.
No need to get a netbook then, imho.
Even if you have to spend on a new power brick later, as you are scared it may conk out due to overheating, it may still cost you way less than what a new netbook costs.
We may think a low power desktop rig consumes almost as much power as a laptop does during idle.
But first of all, we need a very efficient PSU.
For an Atom-based rig, pico-psu is a brilliant option but it is not exactly cheap.
The main advantage that laptops enjoy when tuned to consume low power are
- the components are designed to operate at low TDP
- the power brick for the laptop is usually way more efficient than most good PSUs, even 80 plus certified units iirc.
- power management solutions for laptops are more comprehensive compared to usual desktop ones and also more ffective usually
31-08-2010, 11:09 PM
#22 (permalink)
Point Blanc
another of nice threads.
I am using HP Elitebook 8440p, it comes with a power consumption meter, I have seen it as low as 18.1 when very less apps are open(wireless off), and right now it is showing 29.1 ( with firefox IE winscp adobe reader eclipse open and wireless on). I am amazed with the counts
This is a core i5 540 proccy based lappy.
netbooks consume lesser power because of atom, but rest(mobo and other components) are not that good(Sony netbooks come in 45K), intel U series procies are also low power consuming proccy series.
a HP dv6 with core i5 I am sure would consume one and half to double i.e 45-60W power.
samsung netbook model which has wi-fi has bluetooth also, and I would rate samsung netbooks to be the best, infact their laptops are also very good.
