Old 24-08-2010, 08:02 PM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Unhappy Monitor VGA cable problem????
My VGA cable is bent at a sharp angle right where it connects to my Graphic card. It has been so for quite some time.
It's only recently that I've been getting problems with it, i.e., I will only see Cyan, or Yellow, or Magenta, or Red, or Blue on screen, or any combination of these colors. I twist it little bit and solving problem,but it's getting worse day by day.
There's nothing wrong with my monitor or video card, it's only the last couple of inch of the cable that's the problem.
Is there any solution? Can i replace VGA cable?
My Monitor is SAMSUNG SYNC MASTER 591s(2004).
THANKS IN ADVANCE!
AMD Athlon II X4 620,2GB DDR2 Kingston 800MHz,BIOSTAR TA790GXB A2+,Cooler Master Extreme Power Plus 450w,Zotac 9600GT 512MB,Dell Inspiron N5030,Creative EP 630,Sony Ericsson J105i Naite.
IronCruz is offline   Reply With Quote
Old 24-08-2010, 08:41 PM   #2 (permalink)
Default Re: Monitor VGA cable problem????
buy a new one. thats the only solution.
Sam is offline   Reply With Quote
Old 24-08-2010, 09:56 PM   #3 (permalink)
What The.... !!!
funkysourav's Avatar
hi pai girish
i am using the same monitor
with the same problem
my problem was that the vga adapter on the mobo was broken
so i solved the problem by replacing the vga adapter from my local repairman
working famously since
funkysourav is offline   Reply With Quote
Old 25-08-2010, 09:05 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
for those earlier monitor the VGA Cable is non detachable its already connected to the Monitor. Take the monitor to the vendor, he can solve the problem
VarDOS is offline   Reply With Quote
Old 25-08-2010, 10:58 AM   #5 (permalink)
Cool Buddy's Avatar
yeah, you'll have to get it replaced at a repair shop coz it can't be detached.
Next time be careful not to bend the VGA cable like that as it is not very flexible.
Nokia 5230 :(
Canon IXUS 115 HS :)
Odd problem : Need Help Anx02 Hardware Q&A 22 22-08-2010 01:52 PM
Is this a power supply problem or Geforce Graphics card problem? vps85 Graphic cards 13 09-08-2010 07:36 AM
Nokia ovi music problem with windows 7 pranav.tally Software Q&A 1 07-08-2010 09:50 AM
Strange auto disconnect problem in windows 7 ayushman9 Software Q&A 1 28-04-2010 02:18 AM
Monitor Problem drsethi Hardware Q&A 0 23-04-2010 09:53 PM
