1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A
ownloading and storeing data.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:yes
3. What is your MAX budget?
A:10-15
4. Planning to overclock?
A:no
A:winxp barebone/win 7 if it can bear
A:2-4 tb
7. What resolution will the screen run at & whats the size of the screen you want?
A:1024x768
A:5
A:myself
A:Min september
A:If this pc runs for 24X7 , I really dont have any idea for how much days will it stand still
A:lcd/No speaker for this system/meyboard mouse
A:kolkata
A:This pc will be running like a personal server entirely for my use.
